Sketch Tooltip Options Coordinate Input for all vertices
200
07-02-2026 03:06 PM
SebastianKrings
via sketchTooltipOptions it is possible to enable Coordinate-Input.
Unfortunately I do not get it working except for once and only for the very fist vertex.
To activate Tooltip one presses tab button. The tooltip opens. On activated coordinates it shows inputs to out in coordinates.
It looks like this:
Right before clicking tab of the very first point:
Right after clicking tab of the very first point:
It seems I only can set the coordinate by left clicking on the map after fixing the coordinates.
Hitting Enter only collapses the tooltip.
Right after left clicking the tooltip changes. It does not show coordinate tooltip any more, instead it shows deflection mode:
Our customer wants to input every coordiante of the polyline or polygon. One after the other.
How do I achieve that?
I used this page to work with a sample:
https://developers.arcgis.com/javascript/latest/sample-code/sketch-geometries/
I used this sketch in the linked codepen to enable coordiante input:
const sketch = new Sketch({
  layer: graphicsLayer,
  view: view,
  // graphic will be selected as soon as it is created
  creationMode: "update",
  tooltipOptions: {enabled: true, visibleElements: {coordinates: true}}
