skech widget is ignoring availableCreateTools property
451
05-29-2025 02:31 PM
RakeshAjwani
I am trying to create a sketch widget in esri javascript. I am using the 4.30 libraries. I am setting a property called availableCreateTools and giving it 6 or 7 tools but the api just does not render the tools I am providing. It goes back to default values.
Here is my code, attached is the screenshot from the debugger.
  sketch = new Sketch({
      layer: graphicsLayer,
      view: view,
     availableCreateTools: ["point", "polyline", "rectangle", "freehandPolygon", "multipoint", "freehandPolyline", "polygon"],
      creationMode: "update"
Is this a server side setting that needs to change or a bug in the api or is there a different way to achieve this?
Any insight is appreciated.
Best
Rakesh
JoelBennett
MVP Regular Contributor
The Sketch widget overrides the value of availableCreateTools supplied in the constructor.  Whether that's a bug or not is debatable (I would suggest that it is), but whatever the case, you should be able to set it after the constructor instead:
	view: view,
sketch.availableCreateTools = ["point", "polyline", "rectangle", "freehandPolygon", "multipoint", "freehandPolyline", "polygon"];
JoelBennett
	view: view,
