Simulate pan
2451
12-06-2016 07:07 AM
ChristopherJohnson1
I thought that I had seen some posts on here that simulate a pan on a map...but not actually panning on the map.  Can someone point me in the direction of some code to accomplish that task?
Setting the panDuration and then calling panUp and then panDown immediately?
Thanks...Chris
ChristopherJohnson1
Hi, Robert.  This was resolved with the resolution to the other issue -- https://community.esri.com/thread/186877-feature-table-refresh .  Thanks!
RobertScheitlin__GISP
Chris,
   What are you trying to do? Force and extent-change event?
ChristopherJohnson1
Hi, Robert.  Yes, but map.setExtent() is not invoking the behavior that I want (updating the feature table); panning is.
Thanks...Chris
Chris,
   What about map.setExtent(yourextent, true);
ChristopherJohnson1
I think that I tried that, as well.  Your response to my other question may resolve this issue.  I will let you know when I try that one.
Thanks...Chris
ChristopherJohnson1
