SimpleFillSymbol Outline Color
6379
03-20-2012 10:25 AM
JamesVillanueva
When the SimpleFillSymbol is created as seen below:
var sfs = new esri.symbol.SimpleFillSymbol(style, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.SOLID, new dojo.Color("FFE01B6A"),2), new dojo.Color("FF1B1EE0"));
The outline color remains set to black. It should be set to blue. The color can be set manually after the SimpleFillSymbol is created:
sfs.outline.color = new dojo.Color("FF1B1EE0");
Is this a known issue?
derekswingley1
When you specify your line symbol for your fill symbol, you need to specify a valid constant for style. esri.symbol.SimpleLineSymbol.SOLID is not valid. Try esri.symbol.SimpleLineSymbol.STYLE_SOLID. Alternatively, rather than the long name, you can specify a string, like "solid". Refer to the constants table here:  http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/simplelinesymbol.htm
Edit:  this post was in reference to one that was deleted...but this info is still relevant.
HemingZhu
For dojo.Color construct, you either put RGB (or RGBA) -[R, G, B (, A)], or Hex string -#AABBCC, or Color Name -"White".
derekswingley1
"FF1B1EE0" isn't valid input for dojo.Color. As Heming said, dojo.Color needs a string("white"), a hex string("#fff"), or an array of rgb or rgba values([255, 255, 255] or [255, 255, 255, 1]).
JamesVillanueva
I tried your suggestion and it didn't work. The outline color rgb was still set to 0,0,0. I had to set the outline color on the SimpleFillSymbol after it was created in order to get it to set correctly.
What you said initially made sense,but the string was ingested and created the proper RGB within the dojo color object. The issue appears to be the ESRI SimpleFillSymbol constructor not setting the outline color properly.
derekswingley1
JamesVillanueva
Thanks for the help. That was the cause of the issue.
