Simple way to get camera position?
2651
8
11-08-2016 06:47 AM
MeganWirth
Is there a simple way to set a scenes camera position? i.e. Lat, long, z, heading, and tilt? I ask because i spend a lot of time trying to set these parameters in the api.
RobertScheitlin__GISP
Ryan,
   Sure use:
// Clone the camera to modify its properties
var camera = view.camera.clone();
// Set new values for heading and tilt
camera.heading = 180;
camera.tilt = 45;
// Set the new properties on the view's camera
view.camera = camera;
MeganWirth
Thanks for the reply Robert hope all is well with you.
I believe I need to rephrase the question. Is it possible to be able to pan, tilt  and zoom a scene manually and then be able to see the camera parameters so that you can set the camera position values for the camera? Sorry hard to explain ha
Ryan,
   Ok, now I understand. You can use your browsers developer tools to watch the cameras properties:
Watch variables in Sources  |  Web  |  Google Developers
MeganWirth
Robert Can you show me a screen grab of this working? Would appreciate it man I have tried and tried to get it to work.
Ryan,
  Sure here it is:
KenBuja
MVP Esteemed Contributor
The other way to do it is in the code. You can set up watches on different properties
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Get started with SceneView - Create a 3D map - 4.1</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.1/esri/css/main.css">
  <script src="https://js.arcgis.com/4.1/"></script>
  <script>
    require([
      "esri/Map",
      "esri/views/SceneView",
      "dojo/domReady!"
    ], function(Map, SceneView) {
      var map = new Map({
        basemap: "streets",
        ground: "world-elevation"
      var view = new SceneView({
        container: "viewDiv",
        map: map,
        scale: 50000000,
        center: [-101.17, 21.78]
      view.watch('camera.tilt', function(newValue, oldValue, property, object) {
          console.log(property , newValue);
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
Take a look at the Watching Properties section: Working with properties | ArcGIS API for JavaScript 4.1
MeganWirth
Thank you guys for taking the time to help! appreciate it
No problem. Be sure to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
