Simple ComboBox and queryTask - Not getting desired results
4751
02-03-2015 12:04 PM
KeithAnderson
Friends
Edit fiddle - JSFiddle
jsFiddle link above is simple but I cannot get any field to populate other than OBJECTID.
Initially trying to return distinct values from map service, which works in the REST interface, but not for me in code.
Any suggestions welcome.
Keith
ReneRubalcava
Esri Frequent Contributor
The code in this sample a little old, as I think ItemFileReadStore is deprecated, but I was able to get it to work by removing the "identifier" in your data. I think the "identifier" has to a numeric field... I think.
This worked for me
var query = new esri.tasks.Query();
query.where = "1=1";
query.returnGeometry = false;
query.returnDistinctValues = true;
query.outfields = ["FIELD_NAME"];
//query.orderByFields = ["FIELD_NAME"]; // only works in 10.1 services, this one is 10.01
getList.queryFeatures(query, function (featureSet) {
    //Populate dropdown list
    var values = dojo.map(featureSet.features, function (feature) {
        return {
    var dataItems = {
        label: 'name',
        items: values
    var store = new dojo.data.ItemFileReadStore({
        data: dataItems
That populated the dropdown with the field names.
Here is the docs on Combox with samples using the dojo/store to populate the dropdown.
ReneRubalcava
This worked for me
        return {
    var dataItems = {
        label: 'name',
        items: values
        data: dataItems
KeithAnderson
Thank you again Rene.
It worked.
I will work to change the store.
Keith
