Showing Label OR TextSymbol in NA RouteResult
1784
02-08-2012 09:37 AM
GregoryMeyer
We Currently have a Network Analyst routing application in ArcGIS Server 10 that will return a PictureMarkerSymbol for each barrier along a route.
Is it possible to call a textsymbol or "label" displaying atop this PictureMarkerSymbol?  We would like to show the ID number (from a feature class) of each barrier in the routing result.
It looks like it can only return graphics?  Any thoughts would be helpful.
Thanks!
derekswingley1
You would add a new symbol along with the other symbols you're adding. My point graphic performance demo has some code to create text symbols. Specifically:
symbols.text = new esri.symbol.TextSymbol("Text", font, new dojo.Color([128, 0, 0, 1])).setAngle(0).setOffset(0, 0);
The first parameter to the TextSymbol constructor is a string specifying the text to be displayed.
derekswingley1
If I understand correctly, you want to put some text above a picture marker symbol? You can use a TextSymbol to do this.
Also, you marked your post as an answer. I'm not sure why you're even allowed to do that (forum software, not your fault) but can you see if you can undo that?
GregoryMeyer
Thanks for your reply. That's exactly what I'm trying to do. I came across the TextSymbol class but wasn't exactly sure on how to impliment it in the routeresult.
Would it be placed in the esri.symbol.PictureMarkerSymbol code below? Could you provide an example? (new to javascript api).
Thanks again!
var overviewMapDijit = new esri.dijit.OverviewMap({
map: map,
visible: true
overviewMapDijit.startup();
routeTask = new esri.tasks.RouteTask(naURL);
//setup the route parameters
routeParams = new esri.tasks.RouteParameters();
routeParams.stops = new esri.tasks.FeatureSet();
routeParams.outSpatialReference = { "wkid": mapWKID };
dojo.connect(routeTask, "onSolveComplete", showRoute);
dojo.connect(routeTask, "onError", errorHandler);
startSymbol = new esri.symbol.PictureMarkerSymbol('images/marker_start.png', 20, 34)
startSymbol.setOffset(0, 14);
stopSymbol = new esri.symbol.PictureMarkerSymbol('images/marker_stop.png', 20, 34)
stopSymbol.setOffset(0, 14);
barrierSymbol = new esri.symbol.PictureMarkerSymbol('images/barrier.png', 30, 46)
barrierSymbol.setOffset(0, 0);
highlightSymbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 46, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color("#FF00FFFF"), 2), new dojo.Color([0, 255, 0, 0]))
routeSymbol = new esri.symbol.SimpleLineSymbol().setColor(new dojo.Color([0, 0, 255, 0.5])).setWidth(5);
derekswingley1
GregoryMeyer
Okay, I'll work with this.  Adding it seems to break the initialization of my dropdowns, but this is probably due to my inexperience with the JS api.
Thanks again!
Greg
derekswingley1
Thanks again!
Greg
Cool, start another thread if you can't get it figured out.
