Showing a string field that contains single quote or written accent
1622
10-17-2016 05:03 AM
MargaRaiz
I need to show in a drop-down list the content of the queryresult. This result, has a string field with strings that sometimes has the single quote symbol or the written accent: (  ' or ´  ) and when these strings are shown has the symbol "?" instead of the correct one.
How can I fix it?
Thanks!
Marga
RobertScheitlin__GISP
Marga,
What code are you using to display the result of the query? Are you saying that the FeatureSets feature attributes actually have the "?" in the returned data or is it something about your code for diaplying the results that is adding the "?"  ?
MargaRaiz
My bad, i don't know what was I looking, but it was a different field, I don't know if I can delete this message.
thanks anyway Robert
