Show metadata from SHP exported with ExtractData
1223
12-11-2023 11:37 AM
arc_ticodex
Hello, everyone!
Our team has developed a platform with a JS API that downloads shp from layers from Portal calling the following rest service: arcgis/rest/services/System/SpatialAnalysisTools/GPServer/ExtractData
When we open the downloaded shp in ArcGIS Pro, we can't see the metadata. However, the metadata of the layer can be seen in the Portal.
Does anyone know if this is a limitation of Extract Data tool?
Noah-Sager
Hello @arc_ticodex! If you manually download the shp, do you see the same behavior?
I think this question would get more responses if posed in the Enterprise space:
https://community.esri.com/t5/arcgis-enterprise-questions/bd-p/arcgis-enterprise-questions
arc_ticodex
Yes, when we download manually through the Portal it also behaves the same way.
Thanks for your tip. We'll post it in the Enterprise space.
