Show Map Like an image
1530
04-20-2020 03:31 AM
rsharma
I want to show my map on some of my web app pages like an image, that it should be fixed, no zoom in or out, and that image should also show my graphics from different graphics layer
VictorCoelho
You can use the Export Map Service to get a static image of your map
Export a map | ArcGIS for Developers
VictorCoelho
Noah-Sager
Similar to your other question, https://community.esri.com/thread/251863-download-shown-map-as-pdf , you can also use the Print widget and select an image file type in the File format dropdown.
