show layers
957
01-20-2025 01:37 AM
Antonio_Fraga
Hello members of the ESRI community,
I’m starting to work with Calcite and would like to create an application that can basically load a set of predefined layers when the application starts. These layers should have a series of actions (enable, disable, transparency).
I’ve decided to use the list component to manage this. My question is: what’s the best way to specify the layers that should be preloaded? Perhaps through a configuration file?
I’m not sure what the best practice would be in this case. An example would also be very helpful.
Thank you very much!
AndreV
Hi Antonio,
You should use a webmap from Portal or Archos online.
gdi-hohenlohekreis.de
JamesIng
This existing sample might be a good starting point.
https://developers.arcgis.com/javascript/latest/sample-code/layer-list-actions/
It shows how you can config a layerlist widget to control what layers are shown, and control transparency.
James from www.landkind.com
