Show Labels on join Featureclass using arcade Expression
1320
07-05-2022 12:40 AM
cadgism
I made a join between a feature class and a table. Want to show the labels from the table, for which I use the following expression,  it raises an error "bad-arcade-expression". Can someone help me on how can I solve this? Thank you
LabelField = TableNmae.Fieldname
labelExpressionInfo: {
            expression: "$feature." + LabelField
JohannesLindner
Field names of joined tables have to be called using bracket notation.
The resulting  Arcade expression should look like this:
$feature["TableName.FieldName"]
Have a great day!
Johannes
JohannesLindner
Have a great day!
Johannes
cadgism
Perfect , Thank you
