Show Find Task results in DataGrid-JS API 3.1/AGS 10
1348
08-23-2012 07:50 AM
JK
I'm running into an issue where I'm not able to return a list of results into a data grid.  I'm able to make the code work from the "Show Find Task results in DataGrid" section in the Samples section.  So originally I used the text box to enter criteria.  Works fine.  I then decided I needed to control the criteria entered and sent so I replaced the text box with an input select.  It works while keeping the form element's ID the same-makes sense.  However when I change the input select to a dojo input filteringselect it fails to return the data into the data grid.
Sends criteria and return rows:
<input type="text" id="ownerName" size="60" value="Katz" />
<select id="ownerName">
<option value="1">1</option>
Doesn't return rows:
dojo.require("dijit.form.Select");
<select id="ownerName"  data-dojo-type="dijit.form.FilteringSelect">
It appears the criteria is being sent as I can see it when I wrap JS alerts around the values:
alert(dojo.byId("ownerName").value);
alert(findParams.searchText);
It appears the grid load fails grid here: grid.setStore(store);  I'm developing and testing to IE8.  Using Firebug in FF it appears the store variable doesn't contain the records.  I'm not getting any errors so hopefully it's an easy fix.  Any help would be great.  Thanks!
JK
Found the issue.  I replaced findParams.searchText = dojo.byId("ownerName").value; with findParams.searchText = dijit.byId("ownerName").value;
JK
