Show dynamically selected polygons editable when click on map and save all of them
4497
12
03-12-2020 06:08 AM
rsharma
Currently, I am showing dynamic polygon on click of map by getting its lat long but  i  also want to show them editable.
Query: do reshape stop method get geometry of all polygons appeared dynamically or is their any other way to store ring coordinates of all dynamically appeared polygons.
RobertScheitlin__GISP
Rajni,
   No. See the documentation (it really helps to read it when you have a issue).
reshapeThis tool allows the entire graphic or individual vertices of the graphic to be moved. Vertices can be added or removed. This tool can only be used with a single graphic that has a polygon or polyline geometry.
How does that make sense to have more then one polygon editable in reshape mode?
rsharma
Then how can i work with multiple editable polygons or graphics. Is their any other editing option in arcgis 4.14 for polygons , i just want to make everthing editable everytime
Rajni,
   If all graphics are added to the same GraphicsLayer that the SketchViewModel is constructed with then all graphics will be editable after they are clicked. If for some reason you are saying that after your app starts and you have set in your code to have a particular graphic editing in reshape mode then you click on a different graphic and it does does not un-select the current one and move editing to the newly clicked graphic then you are having an issue.
