Show cluster count 1
1058
06-02-2022 08:43 PM
AntonioGallo
Hello,
i am using GeoJSONLayer  with featureReduction to show the cluster in the Map.
I need to show on the map also the cluster that count 1.
I read  that: "There's no such thing as clusters with a count of one. If a feature does not belong to a cluster, it is rendered by itself according the configuration defined in the layer's renderer."
However i do not understand how to define the configuration in the layer's renderer to show point do not clustered on the map.
I am using version javascript 4.23
Tags (1)
KristianEkenes
Hi @AntonioGallo ,
The configuration API for cluster labels and popups is very similar to the layer labels and popups. To label clusters and individual features, you need to use the following:
layer.featureReduction = {
  type: "cluster",
  labelingInfo: [
   // define label classes here for clusters
layer.labelingInfo = [{
  // define label classes here for individual features
This sample application does both, though I admit the label classes are a bit more complex as they handle different styles and label placements at various scale levels: https://developers.arcgis.com/javascript/latest/sample-code/featurereduction-cluster-filter-slider/
See the image below:
The green point indicated by the red arrow is an individual power plant. It is not labeled with a "1", but rather with the information for the plant itself in the layer.lablingInfo property (since it is not a cluster). The other blue symbols are clusters of 4 and 5 power plants respectively. Those labels are defined on the layer.featureReduction.labelingInfo property. Notice the label placement is different. That is because each label comes from a different label class, which is defined based on the average size of power plant in the cluster.
Hopefully that helps.
Kristian
