Shortlist Story Map Template js Bug Report - Login Prompt
801
08-05-2013 06:00 AM
SaraFlecher1
I am using the Shortlist story map template using a webmap from my organization's ArcGIS Online account and found a permissions issue. When accessing the story map, the template does not prompt the user for an ArcGIS Online for Organizations user login and only works if the webmap is set to "Public" permissions.
The Shortlist template is using js v.3.2  (http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2) and should be using js v.3.5 (http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/) and the dojo esri.IdentityManager function in order to prompt the user login.
Sara Flecher
