Setting zIndex for dijit/form/button
4964
11
08-29-2013 11:57 AM
by Anonymous User
Not applicable
Is it possible using the following syntax? Seems to have no effect
<button id="locate" data-dojo-type="dijit/form/Button" data-dojo-props="zIndex: 900">Locate</button>
Thanks!
rGibson
JasonZou
No need to set z-index for button here. What makes you want to set z-index? In addition, just learnt today that z-index only works for positioned elements. Please refer to http://coding.smashingmagazine.com/2009/09/15/the-z-index-css-property-a-comprehensive-look/.
<button id="locate" data-dojo-type="dijit/form/Button">Locate</button>
I can display the button without any problem. See http://jsfiddle.net/4Dm7y/.
JasonZou
data-dojo-props is used to set the properties for dijit/form/Button, not for style settings. Use style to set css rules.
Try:
<button id="locate" data-dojo-type="dijit/form/Button" style="z-index: 900">Locate</button>
by Anonymous User
Not applicable
Try:
Thanks for the quick reply. I tried that as well and still no luck.
Thanks!
rGibson
by Anonymous User
Not applicable
Try:
Attempting to have the button visible within a div, style by:
div.floating-layerMenu {
     position: fixed;
  right: 35px;
  top: 100px;
  background: #000000;
  border: 0;
  z-index: 1;
  padding: 0px;
  margin: 0 0 0 0px;
  display:none;
JasonZou
z-index is very tricky. Button's z-index only works within the scope of its container, which is div.floating-layerMenu in your case. Is div.floating-layerMenu visible?
by Anonymous User
Not applicable
Initially, no. But at the click from a toolbar it becomes visible.
by Anonymous User
Not applicable
I actually tried...
div.locateBtn {
z-index: 900;
width: 50px;
height: 25px;
which worked but then the button could not be sized. It just appeared as a small, round button.
JasonZou
Can you post the portion of your html? Normally, buttons should resize themselves automatically unless you specifically set their width and height.
by Anonymous User
Not applicable
<div id="findAddress" class="floating-layerMenu" style="width:200px; height:150px;" >
         <h5>Find Address</h5>
  <br>
         <textarea type="text" id="address"/>8813 Meadow Dr, Fort Smith, AR</textArea>
  <br>
</div>
     position: fixed;
  right: 35px;
  top: 100px;
  border: 0;
  z-index: 1;
  padding: 0px;
  margin: 0 0 0 0px;
  display:none;
JasonZou
