Setting map extent to extent of a ArcGISDynamicMapServiceLayer
4485
6
07-03-2013 08:49 AM
baileyhanson
I am having difficulty figuring out how to set the map extent to that of a dynamic layer. Can anyone point me in the right direction?
baileyhanson
I just tried this but it's not changing anything...
var extent = new esri.geomentry.Extent();
  extent.xmin = 256450.78762439353;
  extent.ymin = 4497518.370302271;
  extent.xmax = 643092.2901218915;
  extent.ymax = 4634966.500851203;
  spatialReference = 26915;
NicholasKnabe
          var initExtent = new esri.geometry.Extent({
              "xmin": -102.03,
              "ymin": 33.39,
              "xmax": -101.65,
              "ymax": 33.8,
              "spatialReference": {
                  "wkid": 4326
          map = new esri.Map("map", {
              extent: esri.geometry.geographicToWebMercator(initExtent)
KenBuja
MVP Esteemed Contributor
Here's an example of zooming to the extent of a dynamic map service, using AMD code
<!DOCTYPE html>
<html>
<head>
  <title>Create a Map</title>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
  <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css">
  <style>
    html, body, #mapDiv{
      padding: 0;
      margin: 0;
      height: 100%;
  </style>
  <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script>
  <script>
    var map, layerDynamic;
    require(["esri/map", "dojo/Deferred", "dojo/domReady!"], function(Map, Deferred) {
      map = new Map("mapDiv", {
        center: [-56.049, 38.485],
        zoom: 3,
        basemap: "streets"
      layerDynamic = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/MapServer", {
      map.addLayers([layerDynamic]);
      layerDynamic.on("load", function () {
        var deferred = new Deferred();
        deferred = map.setExtent(layerDynamic.initialExtent, true);
        deferred.then(function () {
            console.log("Extent set");
  </script>
</head>
<body class="claro">
  <div id="mapDiv"></div>
</body>
</html>
baileyhanson
Ken, shouldn't I be able to use this code and replace the ArcGISDynamicMapServiceLayer URL with my URL? It still won't zoom to the layer.
KenBuja
It looks like it has difficult with spatial references other than 102100 and 4326. TUsing a map service with another one gives the following message in the console:
Map: Geometry (wkid: 4269) cannot be converted to spatial reference of the map (wkid: 102100)
What you'll have to do is get the extent of the extent of your dynamic layer and project it into 102100 or 4326 using a geometry service. You can then use the projected geometry to set the map's extent.
baileyhanson
Thanks for the help. I ended up just using this
var map = new esri.Map("mapDiv", {
        extent: new esri.geometry.Extent({
            xmin: -11068326.4061,
            ymin: 4920683.9772,
            xmax: -10034349.7679,
            ymax: 5501319.0439,
         spatialReference: {
              wkid: 102100
