Setting Graphic symbol color after graphics layer is drawn on the map
3333
05-02-2014 07:10 AM
SanthoshKumar3
Hello,
I have a graphics layer drawn on the map with several other layers. I want to set a different color for the symbol based on a condition. So, I have used symbol.SetColor method which does not work.
var layer = map.getLayer('layerid'); layer.graphics[0].symbol.setColor(new dojo.Color("red"));
Any suggestions?
-Santhosh
JohnGrayson
Esri Alum
Suggestions:
  1) Best solution is to add a renderer to the layer based on the conditions so you don't have to worry about changing symbol colors directly.
  2) To change the symbol directly, here are the general steps (not tested):
var layer = map.getLayer('layerid'); // get the symbol var symbol = layer.graphics[0].symbol; // change color symbol.setColor(new dojo.Color("red")); // assign symbol back to graphic layer.graphics[0].setSymbol(symbol);
JohnGrayson
Esri Alum
Suggestions:
SanthoshKumar3
Thanks John. Setting the symbol for the graphic worked. I thought setting the color will refresh the graphic automatically.  I will look up renderer examples in the API documentation. It sounds like that is a clean solution.
