Setting Curb Approach
2949
08-23-2016 02:40 AM
KeithStewart
Hello,
I am using the ArcGIS API for JavaScript to develop a web application that will support routing for buses.  These buses must approach every stop on their routes on the right side of the vehicle.  How can I dictate the approach curb with the ArcGIS API for JavaScript?
Keith
Tags (3)
nita14
Yes, you can. Just add a stop with specific attribute name and value i.e. CurbApproach  1
More info on: ArcGIS REST API
Hope this helps,
Adam
nita14
Hope this helps,
Adam
KeithStewart
This worked well, Nicinski!  Below is how I added the CurbApproach attribute to the stop creation:
      var stop = new Graphic({
        geometry: point,
        symbol: stopSymbol,
        attributes: {
          "CurbApproach": 1
Thanks for your help!
