I'm having an issue with setExtent. If I zoom to a building in Hawaii and then attempt to zoom to a building in South Carolina, the map does not load the second time(same for SC to HI). This is for IE 9. I have done a network capture using Developer Tools. This shows the requests for the tiles have been aborted. The requests do not show up in Fiddler.
It does work when I do a larger level switch from a larger area in HI to a larger area in SC.
Do you know what could be causing this? Thanks in advance.
