set visibility in Legend list
2579
01-28-2013 09:35 AM
BillShockley
I have this for my legend function:
function addLayerList(layers) {
    var layerList = [];
    dojo.forEach(layers, function(layer){
        if(layer.layerInfos){
            dojo.forEach(layer.layerInfos, function(info,index){
                info.id  = layer.id;
                info.subId = index;
                layerList.push(info);
        }else{
            layerList.push(layer);
    if (layerList.length > 0) {
        //create a menu of layers
        layerList.reverse();
        var menu = new dijit.Menu({
        dojo.forEach(layerList, function (layer) {
            menu.addChild(new dijit.CheckedMenuItem({
                label: layer.name || layer.title,
                checked: layer.visible,
                onChange: function (e) {
                    if (layer && layer.declaredClass === 'esri.layers.LayerInfo') {
                        var l = map.getLayer(layer.id);
                        var ids = []
                        if(e){
                            ids.push(layer.subId)
                        }else{
                            ids.push(-1);
                        l.setVisibleLayers(ids);
                    } else if (layer.type === 'Feature Layer'){
                        layer.setVisibility(!layer.visible);
        var button = new dijit.form.DropDownButton({
            label: i18n.tools.layers.label,
            iconClass: "esriLayerIcon",
            title: i18n.tools.layers.title,
            dropDown: menu
        dojo.byId('webmap-toolbar-center').appendChild(button.domNode);
Is there a way to specify which on the my services are visible and which are not by using there ID Numbers?
Any help is much appreciated.
Bill
DianaBenedict
Here is a method that I use to determine if the layer is visible at the current scale.  You need to pass in the infoLayer and the mapscale.  You can get the map scale from the map.getScale() method. The info param should come from your "dojo.forEach(layer.layerInfos, function(info,index)"... info object.
function isLayerInfoVisible(info, mapScale) {
  var isVisible = true;
  if (info.maxScale == 0 && info.minScale == 0) {
    isVisible = true;
  } else {
    if (info.maxScale == 0 && mapScale > info.minScale || info.minScale == 0 && mapScale < info.maxScale) {
      isVisible = false;
    } else if (info.minScale > 0 && info.maxScale > 0) {
      if (mapScale > info.minScale && mapScale < info.maxScale) {
        isVisible = true;
      } else {
        isVisible = false;
    } else {
      isVisible = true;
  return isVisible;
