Set initial value of HORIZONTALSLIDER not working
1323
08-14-2013 06:56 AM
WalterEralio
I have a feature layer with attached dijit horizontalslider
Initially the layer is not visible and I'll like to programatically enable it (I'm doing that) but with the slider set in the middle (value 0.5, i.e. Opacity= 0.5). I cannot do this.. the layer appears with the slider on the beginning but no opacity and as soon as I move it to the right it'll go from 0 to 1
Declaration:
            // FLOOD LAYER
            featureLayerFL = new esri.layers.FeatureLayer('<s:property value = "arcGisFeatureLayerUrl" />/mxds/manmapC/MapServer/12', {
                mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
                outFields: ['*'],
                opacity: 1
            legendLayers.push({
                layer: featureLayerFL,
                title: 'FLOOD'
            featureLayerFL.hide();
            dojo.connect(featureLayerFL, 'onMouseOver', showTooltipFL);
            dojo.connect(featureLayerFL, 'onMouseOut', closeDialogFL);
   featureLayerFloodSlider = new dijit.form.HorizontalSlider();
   featureLayerFloodSlider.id = "Flood Slider";
   featureLayerFloodSlider.value=0.5;
   featureLayerFloodSlider.layerID = 12;
   featureLayerFloodSlider.minimum = 0;
   featureLayerFloodSlider.maximum = 1;
   featureLayerFloodSlider.tooltip = "Flood";
   featureLayerFloodSlider.intermediateChanges = true;
   featureLayerFloodSlider.showButtons = true;
   featureLayerFloodSlider.style = "width:100px";
   //featureLayerFloodSlider.onChange = function(){slideLayerOpacity(12,this.value)}
   featureLayerFloodSlider.onChange = function(){slideLayerOpacity(12,featureLayerFloodSlider.value)}
   featureLayerFloodSlider.handleSrc = "https://serverapi.arcgisonline.com/jsapi/arcgis/1.1/js/dojo/dijit/themes/tundra/images/preciseSlider...";
Part when I make visible and try to set value to 0.5
                   featureLayerFL.setVisibility(true);
                   map.graphics.refresh();
JasonZou
Try this.
Change:
To:
featureLayerFloodSlider.set("value", 0.5);
featureLayerFL.setOpacity(0.5);
