Set Default Basemap to Our OWN Local Map Server
1522
06-16-2013 03:10 PM
JasonBarles
How do you set the default basemap to something other than the ones provided by ArcGIS online? I am trying to set the default basemap to load one from our local ArcGIS Server.
So far I have got it to load our own basemap after choosing it from the basemap gallery.
This is my current default basemap code, which of course loads an ArcGIS online map:
map = new esri.Map("map", {
   basemap: "satellite",
   center: [150.8263120280644, -22.003174],
   zoom: 3
Thanks in advance!
ManojrajTeli
You can do this
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://yourServerLink/MapServer", { useMapImage: true, "id": "Basemap" });     map.addLayer(basemap);
dont use basemap property in map variable.
ManojrajTeli
You can do this
derekswingley1
The tiled map service sample shows how to do this.
JasonBarles
You can do this
Thank you for confirming my code was correct, as that was what I had originally. The issue however was that my browser didn't trust the server where the maps were being hosted.
