Seperate JS files
6046
12
01-31-2018 06:43 AM
jaykapalczynski
Honored Contributor
I have an app that is starting to get a rather large amount of JS.
I was wondering if I could start to separate certain bits of code in a separate JS file and then just reference them.
If I reference it in HTML as I do the main JS file I get errors saying the map is not defined.
<script src="js/index.js"></script>
<script src="js/elevationprofile.js"></script>
Is there a way to reference all the split out JS files in the main JS file?
KenBuja
MVP Esteemed Contributor
So if I comment out almost all of the requires, leaving
require([
   "esri/map", "esri/geometry/webMercatorUtils", "dojo/dom", "dojo/parser",//"esri/dijit/Legend", //"esri/symbols/SimpleFillSymbol",
    //      "esri/geometry/Extent", "esri/layers/ArcGISDynamicMapServiceLayer", 'esri/layers/WMSLayer', 'esri/layers/WMSLayerInfo', "esri/layers/ImageParameters",
    //      "dojo/_base/array", "dojo/on", "esri/graphic", "esri/graphicsUtils", "esri/tasks/Geoprocessor", "esri/tasks/FeatureSet", "esri/tasks/LinearUnit", "esri/symbols/SimpleLineSymbol",
    //      "esri/renderers/SimpleRenderer", "esri/symbols/SimpleMarkerSymbol", "esri/layers/LabelClass", "esri/dijit/BasemapToggle", "esri/dijit/HomeButton", "esri/dijit/Search", "esri/dijit/LocateButton",
    //    "esri/urlUtils", "esri/dijit/Directions",
    //      "esri/toolbars/draw", "esri/symbols/CartographicLineSymbol", "esri/units", "esri/dijit/ElevationProfile",
    //      "esri/Color", "dojo/_base/array",  "esri/InfoTemplate", "esri/renderers/ClassBreaksRenderer", "dijit/form/CheckBox", "dojo/dom-construct",
    //      "dojo/keys", "esri/SnappingManager", "esri/dijit/Measurement", "esri/tasks/GeometryService", "esri/config", "esri/sniff", "esri/dijit/BasemapGallery",
    //      "esri/layers/LabelLayer", "esri/symbols/TextSymbol", "esri/symbols/Font", "esri/symbols/SimpleLineSymbol",
    //    "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/layout/AccordionContainer", "esri/dijit/Scalebar", "dijit/TitlePane", "dojo/domReady!"
 "dojo/domReady!"
], function (Map, webMercatorUtils, dom, parser
    //Map, webMercatorUtils, dom, FeatureLayer, Legend, SimpleFillSymbol,
    //  Extent, ArcGISDynamicMapServiceLayer, WMSLayer, WMSLayerInfo, ImageParameters,
    //  array, on, Graphic, graphicsUtils, Geoprocessor, FeatureSet, LinearUnit, SimpleLineSymbol,
    //  SimpleRenderer, SimpleMarkerSymbol, LabelClass, BasemapToggle, HomeButton, Search, LocateButton,
    //urlUtils, Directions,
    //  Draw, CartographicLineSymbol, Units, ElevationsProfileWidget,
    //  Color, arrayUtils, parser, InfoTemplate, ClassBreaksRenderer, CheckBox, domConstruct,
    //  keys, SnappingManager, Measurement, GeometryService, esriConfig, has, BasemapGallery,
    //  LabelLayer, TextSymbol, Font, SimpleLineSymbol
then the code works. If I uncomment the next module, "esri/layers/FeatureLayer", then the code fails. The time it takes to load all those modules was causing a problem. To fix that, I used dom/ready on the other js file. This makes
require(["dojo/ready", "esri/map", "dojo/domReady!"], function (ready, Map) {
    ready(function () {
        map.on("click", function (e) {
            alert("clicked");
From the documentation
dojo/ready registers a function to run when the DOM is ready and all outstanding require() calls have been resolved, and other registered functions with a higher priority have completed.
jaykapalczynski
Honored Contributor
I tried this:
Added this to HTML under my main js file
<!-- New reference to js file  -->
<script src="js/elevationprofile.js"></script> ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
<!-- SNIP -->
<div id="map" class="shadow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="region:'center'" style="height:100%">
    <div id="LocateButton" data-dojo-props="region:'center'"></div>
     <div id="HomeButton"></div>
     <div id="search"></div>
        <div id="profilecontainer" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'bottom'" >
     <div id="profileChartNode"></div>
    </div>
</div>
Added this new js file
require([
     "esri/map","dojo/domReady!"
], function(
     Map
    map.on("click", function(e){
        alert("clicked");
I get this error:
init.js:28 Uncaught TypeError: map.on is not a function
    at elevationprofile.js:7
    at ia (init.js:28)
    at init.js:28
    at ja (init.js:28)
    at ga (init.js:28)
    at f (init.js:30)
    at HTMLScriptElement.<anonymous> (init.js:35)‍‍‍‍‍‍‍‍
KenBuja
Where are you setting a reference to "map"?
jaykapalczynski
Honored Contributor
I'm not in the 2nd js file...I was following this example towards the bottom.  They dont set the reference in the 2nd js file as I can see.
creating javascript external file for map function
confused.
I am doing so in the main js file
var map = new Map("map", {
  basemap: "gray",
  center: [-79.665, 37.629],
  zoom: 8,
  logo: false,
  showLabels : true
KenBuja
If you look at the other example, it declares "map" outside the require section in the first js file. You're declaring it inside.
var map;
require(["esri/map", "dojo/domReady!"],function(Map) {
    basemap: "topo",
    center: [-122.45, 37.75], // longitude, latitude
    zoom: 13
jaykapalczynski
Honored Contributor
Yea thats what I am doing....in the original js file
      require([
        "esri/map", "esri/geometry/webMercatorUtils", "dojo/dom", "esri/layers/FeatureLayer", "esri/dijit/Legend","esri/symbols/SimpleFillSymbol",
          "dojo/_base/array", "dojo/on", "esri/graphic","esri/graphicsUtils","esri/tasks/Geoprocessor","esri/tasks/FeatureSet","esri/tasks/LinearUnit","esri/symbols/SimpleLineSymbol",
          "esri/renderers/SimpleRenderer", "esri/symbols/SimpleMarkerSymbol","esri/layers/LabelClass", "esri/dijit/BasemapToggle","esri/dijit/HomeButton", "esri/dijit/Search", "esri/dijit/LocateButton",
          "esri/toolbars/draw","esri/symbols/CartographicLineSymbol","esri/units","esri/dijit/ElevationProfile",
          "esri/Color", "dojo/_base/array", "dojo/parser", "esri/InfoTemplate", "esri/renderers/ClassBreaksRenderer","dijit/form/CheckBox", "dojo/dom-construct",
          "dojo/keys","esri/SnappingManager","esri/dijit/Measurement","esri/tasks/GeometryService","esri/config",     "esri/sniff","esri/dijit/BasemapGallery",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/layout/AccordionContainer","esri/dijit/Scalebar","dijit/TitlePane", "dojo/domReady!"
      ], function(
          keys,SnappingManager, Measurement, GeometryService,esriConfig, has,BasemapGallery,
     var dojoConfig = { parseOnLoad: true };
        var legendLayers = [];
     parser.parse();
     // VARIABLES FOR ELEVATION WIDGET
     var tb, epWidget, lineSymbol;
     var gp, mapClickEvt;
      basemap: "gray",
      zoom: 8,
       logo: false,
       showLabels : true
// SNIP  bunch of code for other stuff
KenBuja
You have to declare variable "map" before line 1
var map;
require([
then on line 35, you would use
  basemap: "gray",
  zoom: 8,
  logo: false,
  showLabels : true
jaykapalczynski
Honored Contributor
I moved to the top in my main js file
var map;
 require([
      ], function(
    parser.parse();
      basemap: "gray",
      zoom: 8,
      logo: false,
      showLabels : true
I then have this in my 2nd js file
require([
    ], function(
        Map
        alert("clicked");
I know get this error
init.js:28 Uncaught TypeError: Cannot read property 'on' of undefined
at ia (init.js:28)
at init.js:28
at ja (init.js:28)
at ga (init.js:28)
at f (init.js:30)
KenBuja
require([
 "dojo/domReady!"
    ready(function () {
            alert("clicked");
jaykapalczynski
Honored Contributor
OK I removed dojo/domReady and replaced with dojo/ready and it works...go figure...
THANKS..
