selectQuery.Geometry?
1174
06-06-2012 11:34 AM
akpagaakpaga
In the sample beolw
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/ed_attribute_i...
what does this line signify..selectQuery.geometry = evt.mapPoint;
Somehow I am not able to return  evt.mappoint  objetct that it needs to return when I add an alert(map.evt)..Can someone guide me on this
Thank you in advance
JeffPace
In the sample beolw
its in the onclick event, so it is setting the selection location (the query's geometry, i.e. where to search) to the coordinates of the evt
Since the onclick is in screen geometry (pixel height/width) the event (evt or click) 's mapPoint property is "where the user clicked the map in map units).
akpagaakpaga
Thank you jeff.
