Selecting Points under Polygon
3689
7
08-31-2010 03:15 AM
RohitGarg
Hello All,
I have created polygon, now i want to select points under polygon on click... please help me..
this is my code:-
[HTML]
  <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.6" type="text/javascript"></script>
  <script type="text/javascript">
    dojo.require("esri.map");
    dojo.require("esri.tasks.geometry");
    dojo.require("esri.geometry");
    var map = null;
    var gsvc = null;
    var qtask = null;
    var polygonGraphic = null;
    var queryGraphic = null;
    function initialize() {
      map = new esri.Map("map");
      dojo.connect(map, "onLoad", function () {
        drawPolygon();
   var layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://myserver:8399/arcgis/rest/services/Data_Demo/MapServer/");
   map.addLayer(layer);
      map.setExtent(new esri.geometry.Extent(72.81, 18.95, 72.85, 18.98, new esri.SpatialReference({wkid: 4326})));
      gsvc = new esri.tasks.GeometryService("http://myserver:8399/arcgis/rest/services/Geometry/GeometryServer");
   qtask = new esri.tasks.QueryTask("http://myserver:8399/arcgis/rest/services/Data_Demo/MapServer/2");
function drawPolygon() {
      var latOffset, lonOffset, center, lat, lon, points;
       center = map.extent.getCenter();
     var Lat = 76.85; var Lon = 26.298; var Lat1= 72.8296; var Lng1= 18.99522;
     var Lat2= 72.819175; var Lng2= 18.970838; var Lat3= 72.828; var Lng3= 18.969;
     var Lat4= 72.832; var Lng4= 18.951; var Lat5= 72.823697;var Lng5= 18.946847;
    var Lat6= 72.826775035; var Lng6= 18.93383939; var Lat7 = 72.8150861175;
   var Lng7 = 18.96397220334;var Lat8 = 72.81860278088;var Lng8 = 18.951649999;
    var polygon  = {"rings":[[[Lat1,Lng1],[Lat3,Lng3],[Lat6,Lng6], [Lat5,Lng5],[Lat8,Lng8],[Lat7,Lng7], [Lat2,Lng2], [Lat1,Lng1]]],
  "spatialReference":{" wkid":4326 }};
  var polygon = new esri.geometry.Polygon(polygon);
      var symbol = new esri.symbol.SimpleFillSymbol().setStyle(esri.symbol.SimpleFillSymbol.STYLE_SOLID);
      polygonGraphic = new esri.Graphic(polygon, symbol);
      map.graphics.add(polygonGraphic);
    function doSimplify() {
gsvc.simplify([ polygonGraphic.geometry ], doQuery(polygonGraphic));
    function doQuery(polygonGraphic) {
      var query = new esri.tasks.Query();
      //query.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
      query.spatialRelationship = esri.tasks.Query.SPATIAL_REL_CONTAINS;
      query.geometry = polygonGraphic.geometry;
      query.returnGeometry = true;
      qtask.execute(query, queryCallback);
    function queryCallback(featureSet) {
      map.graphics.remove(queryGraphic);
  var symbol = new esri.symbol.SimpleMarkerSymbol();
          symbol.style = esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE;
          symbol.setSize(8);
          symbol.setColor(new dojo.Color([255,255,0,0.5]));
      var features = featureSet.features;
      var point = new esri.geometry.Point();
      queryGraphic = new esri.Graphic(point,symbol)
      map.graphics.add(queryGraphic);
    dojo.addOnLoad(initialize);
  </script>
</head>
<body class="tundra">
  <input type="button" value="Simplify the polygon and Do a Query with simplified polygon" onclick="doQuery(polygonGraphic);" />
    <div id="map" style="width:600px; height:400px; border:1px solid #000;"></div>
</body>
</HTML>
derekswingley1
There are a few issues...
-your doSimplify function is never used
-you don't need to pass in your polygonGraphic to doQuery since polygonGraphic is global
I put together a working example using services hosted by esri:
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<title></title>
<link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/1.6/js/dojo/dijit/themes/tundra/tundra.css">
<style>
 html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
</style>
 var map = null;
 var gsvc = null;
 var qtask = null;
   drawPolygon();
  var layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer");
  map.setExtent(new esri.geometry.Extent({"xmin":-115.960,"ymin":36.524,"xmax":-115.734,"ymax":36.648,"spatialReference":{"wkid":4269}}));
  gsvc = new esri.tasks.GeometryService("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
  qtask = new esri.tasks.QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/0");
   [-115.930, 36.540],
   [-115.740, 36.540],
   [-115.740, 36.640],
   [-115.930, 36.640],
   [-115.930, 36.540]
  "spatialReference":{" wkid":4269}};
 function doQuery() {
  symbol.setSize(8);
  dojo.forEach(features, function(feature) {
   feature.setSymbol(symbol);
   map.graphics.add(feature);
</script>
</head>
<input type="button" value="Query for points within the polygon graphic." onclick="doQuery();" />
<div id="map" style="width:1000px; height:600px; border:1px solid #000;"></div>
</body>
</html>
RohitGarg
Thanks Derek, Great... now its working fine in my application.
<html>
<head>
<title></title>
<style>
</style>
 var map = null;
 var gsvc = null;
 var qtask = null;
   drawPolygon();
   [-115.930, 36.540],
   [-115.740, 36.540],
   [-115.740, 36.640],
   [-115.930, 36.640],
   [-115.930, 36.540]
  symbol.setSize(8);
</script>
</head>
</body>
</html>
RohitGarg
Hello Derek,
I have a one query. Like I have one polygon and one Polyline, If Polyline cross Polygon then it will through error alert message.
Can you please help me.
Regards,
RG
email:[email protected]
derekswingley1
What is the error message?
RohitGarg
Thanks for the reply... I want show error alert, if polyline touches/crossess polygon, it should throw some error like "polyline cross the line" with line name.
RohitGarg
Hello Derek,
Below is my code :-
<html>
<head>
<title></title>
<style>
</style>
var map = null;
var gsvc = null;
var qtask = null;
   drawPolygon();
  var layer = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyBasemap/MapServer/");
  map.setExtent(new esri.geometry.Extent({"xmin":-85.96,"ymin":37.985,"xmax":-85.385,"ymax":38.393,"spatialReference":{"wkid":4326}}));
  qtask = new esri.tasks.QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyBasemap/MapServer/12");
   [-85.950, 38.000], [-85.0, 37.9],
   [-85.440, 38.540],
   [-85.740, 38.640],
   [-85.930, 38.640],
   [-85.950, 38.000]
  "spatialReference":{" wkid":4326}};
  query.spatialRelationship = esri.tasks.Query.SPATIAL_REL_TOUCHES;
  alert("hidoQ");
var symbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0,0,0]), 5);
  alert("1");
  dojo.forEach(features, function(feature){feature.setSymbol(symbol); map.graphics.add(features);
   alert("5");
</script>
</head>
<input type="button" value="Query for points within the polygon graphic." onClick="doQuery();" />
<div id="map" style="width:800px; height:400px; border:1px solid #000;"></div>
</body>
</html>
RohitGarg
Hello,
I have 2 polygon, I want to select those point which is under Polygon 2. Is it possible ?
Below is the code shows 2 polygons and selecting all points(under polygon 1 and polygon 2).
<html>
<head>
<title></title>
<style>
</style>
var map = null;
var gsvc = null;
var qtask = null;
var polygonGraphic2 = null;
var extent = null;
   drawPolygon();
   drawPolygon2();
  extent = map.setExtent(new esri.geometry.Extent({"xmin":-115.960,"ymin":36.524,"xmax":-115.734,"ymax":36.648,"spatialReference":{"wkid":4269}}));
   [-115.930, 36.540],
   [-115.740, 36.540],
   [-115.740, 36.640],
   [-115.930, 36.640],
   [-115.930, 36.540]
  var symbol = new esri.symbol.SimpleFillSymbol().setStyle(esri.symbol.SimpleFillSymbol.STYLE_NULL);
function drawPolygon2() {
  var polygon2 = {"rings":[[
   [-115.950, 36.520],
   [-115.740, 36.520],
   [-115.740, 36.650],
   [-115.950, 36.650],
   [-115.950, 36.520]
  var polygon2 = new esri.geometry.Polygon(polygon2);
  var symbol2 = new esri.symbol.SimpleFillSymbol().setStyle(esri.symbol.SimpleFillSymbol.STYLE_CROSS);
  polygonGraphic2 = new esri.Graphic(polygon2, symbol2);
  map.graphics.add(polygonGraphic2);
  query.geometry = polygonGraphic2.geometry;
  symbol.setSize(15);
</script>
</head>
</body>
</html>
