Selecting a group of features
8320
23
09-18-2015 08:34 AM
DaveSouthern
I'm looking for a way to use the mouse to select a group of features on a map by dragging a rectangle around them.  I can select a single feature on the map by simply clicking on that feature - that much I have working.  But now I want to be able to drag a rectangle around a group of features and select all of them so I can do something with all of them.  So far I haven't found any code examples out there that discuss this.
thejuskambi
I am wondering if you are targeting the correct layer. Please ensure the Graphics you intend to select are part of the map.graphics layer and not some other FeatureLayer/GraphicsLayer.
DaveSouthern
They are part of a feature layer.  Is that the issue?  If so, how do I target a feature layer?
thejuskambi
If they are part of Featurelayer then you cannot use map.graphics.graphics. You would have to query or select feature with the methods in FeatureLayer
  var query = new Query();
  query
.geometry = evt.geomtry;
  query
.outFields = [ "*" ];
// Query for the features with the given object ID
  featureLayer
.queryFeatures(query, function(featureSet) {
     //TODO: use the features
DaveSouthern
OK. So I tried the following:
       var featureLayer = map.getLayer(layerId);
        require(["esri/tasks/query"], function (Query) {
            query.geometry = evt.geomtry;
            query.outFields = ["*"];
            featureLayer.queryFeatures(query, function (featureSet) {
But I get the error "Object doesn't support property or method 'queryFeatures'"  So... maybe I don't have a feature layer after all.  What else is there?
