Selecting a group of features
8133
23
09-18-2015 08:34 AM
DaveSouthern
I'm looking for a way to use the mouse to select a group of features on a map by dragging a rectangle around them.  I can select a single feature on the map by simply clicking on that feature - that much I have working.  But now I want to be able to drag a rectangle around a group of features and select all of them so I can do something with all of them.  So far I haven't found any code examples out there that discuss this.
JakeSkinner
Esri Esteemed Contributor
Hi Dave,
Here is a quick example on how to select features using a freehand drawn polygon:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Select Features</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <style>
      html, body, #mapDiv {
        padding:0;
        margin:0;
        height:100%;
    </style>
    <script src="http://js.arcgis.com/3.14/"></script>
    <script>
      var map, tb, polygon;
      require([
        "esri/map", "esri/toolbars/draw", "esri/layers/FeatureLayer", "esri/tasks/query",
        "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleMarkerSymbol",
        "esri/graphic", "esri/geometry/Polygon",
        "dojo/_base/Color", "dojo/dom", "dojo/on", "dojo/_base/array", "dojo/domReady!"
      ], function(
        Map, Draw, FeatureLayer, Query,
        SimpleFillSymbol, SimpleLineSymbol, SimpleMarkerSymbol,
        Graphic, Polygon,
        Color, dom, on, array
        map = new Map("mapDiv", {
          basemap: "streets",
          center: [-81.792107, 26.150807],
          zoom: 8
        map.on("load", initToolbar);
        var featureLayer = new FeatureLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/0",{
            mode: FeatureLayer.MODE_ONDEMAND,
        var symbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_CIRCLE,
          12,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_NULL,
            new Color([247, 34, 101, 0.9]),
          new Color([207, 34, 171, 0.5])
        featureLayer.setSelectionSymbol(symbol);
        map.addLayer(featureLayer);
      var fillSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_NULL,
            new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT,
            new Color([255,0,0]), 2)
        function initToolbar() {
          tb = new Draw(map);
          tb.on("draw-end", addGraphic);
          //map.disableMapNavigation();
          tb.activate(Draw.FREEHAND_POLYGON);
        function addGraphic(evt) {
          map.graphics.clear()
          map.graphics.add(new Graphic(evt.geometry, fillSymbol));
          polygon = new Polygon(evt.geometry)
          var query = new Query();
          query.geometry = polygon.getExtent();
          featureLayer.queryFeatures(query, selectInBuffer);
        function selectInBuffer(response){
          var feature;
          var features = response.features;
          var inBuffer = [];
          for (var i = 0; i < features.length; i++) {
            feature = features;
            if(polygon.contains(feature.geometry)){
              inBuffer.push(feature.attributes[featureLayer.objectIdField]);
          query.objectIds = inBuffer;
          featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(features, index){
              for(var i = 0; i < features.length; i++){
                  console.log(features.geometry.x + ", " + features.geometry.y)
    </script>
  </head>
  <body>
    <div id="mapDiv"></div>
  </body>
</html>
DaveSouthern
I've been working with this code, but have a problem with this line:
The error I'm getting is that queryFeatures is not a member of featureLayer.  Now there is a wrinkle on my end that isn't in your example code - I'm extracting the layer from the existing map object - not just creating one. Now as far as I know the layer is a featureLayer, but I may be wrong about that.  The code that creates the layer was written by another developer - I haven't dug it out yet to see if something is amiss there.
ChrisSmith7
Honored Contributor
DaveSouthern
With regard to the example you gave, I get the following:
if (extent.contains(graphic.geometry)) {
contains is not a member of extent.
I tried a hybrid of what you and Jake said, but still can't get things working.  I would show you what I have, but for some reason this editor won't accept the pasted code.
RobertScheitlin__GISP
Dave,
  It really sounds like you have your Requires out of line/out of sync with your vars. Here is an example:
require([
'dojo/on',
'dojo/aspect',
'dojo/_base/lang'], function(
on, aspect, lang) {
DaveSouthern
Did part of your reply get cut off?
Dave,
   Nope. That was it. Notice that the first require "dojo/on" is the first var "on" then the second require "dojo/aspect" is the second var "aspect". Requires and vars have to have this exact one to one ordering. If you mis-order this then you may have your "aspect" var that is actually a "dojo/_base/lang" object and thus it would not have the same properties and methods as you are expecting.
DaveSouthern
Yes, I have my requires setup correctly.
ChrisSmith7
Honored Contributor
David,
Just a heads-up, if you're having trouble with the editor, try:
-> copy code from application
-> paste into a blank notepad document
-> click "use advanced editor"
-> copy code from notepad
-> paste into geonet editor box
-> add a few newlines after the paste with some dummy text
-> select your code block
-> click the ">>" insert function
-> choose "syntax highlighting"
-> then select JavaScript
This should resolve any issues with adding code to geonet.
