Select Widget Changes to Inactive
911
06-26-2020 07:43 AM
NCOneMap
We have the Select Widget in Web AppBuilder Dev Edition set to be active by default, but when we interact with another widget, it goes inactive. When the app initially loads, you can see the Select Widget is active, but as soon as you close the splash screen it goes inactive. You can reactivate it, but if you interact with another widget (infographic for example), it deactivates.
Is there a way to force the Select Widget to remain active at all times?
