Select only features within a drawn polygon
3646
03-30-2016 06:51 AM
RichardMoussopo
I am using query task to select only features within a drawn polygon.
    executeRequestByShape: function () {
                var deffByShape = new Deferred();
                var queryTask = new QueryTask(this.layerUrl);
                var query = new Query();
                query.returnGeometry = true;
                query.geometry = this.geometry;
                query.spatialRelationShip = Query.SPATIAL_REL_WITHIN;
                query.outFields = ["*"];
                var queryResults = queryTask.execute(query);
                var promiseResult = all([queryResults])
                          .then(function (r) {
                              deffByShape.resolve(r);
                return deffByShape.promise;
but this code is returning features that intersect the drawn polygon. Any idea?
BillDaigle
Looks like you have a typo in line 7:
query.spatialRelationShip should be query.spatialRelationship.  Case counts!
RobertScheitlin__GISP
Richard,
  Use SPATIAL_REL_CONTAINS instead.
RichardMoussopo
Thank you Robert for your quick reply. Changed the code to contains and the result is the same. here is what the selection looks like:
I only want the "Yes" to be selected.
BillDaigle
RichardMoussopo
Thank you Bill, Case really counts!
