Select multiple layers with polygon
2652
02-15-2022 02:13 AM
Vakhtang_Zubiashvili
Hi guys,
I have four layers ( names: csvLayer, csvLayer1, csvLayer2, csvLayer3) on my map which have same fields and i have custom html table where i add features selected on map using polygon, but i can add features only from one layer, which is selected in code. In this code i can path one layer, but how can i path all four layers to select features from them? Here is code i use for selecting fatures:
let features = [];
        let csvLayerView;
        csvLayer.when(() => {
          view.whenLayerView(csvLayer).then(function (layerView) {
            csvLayerView = layerView;
        .catch(errorCallback);
        // polygonGraphicsLayer will be used by the sketchviewmodel
        // show the polygon being drawn on the view
        const polygonGraphicsLayer = new GraphicsLayer();
        map.add(polygonGraphicsLayer);
        // add the select by rectangle button the view
        //view.ui.add("select-by-rectangle", "top-left");
        const selectButton = document.getElementById("select-by-rectangle");
        // click event for the select by rectangle button
        selectButton.addEventListener("click", () => {
          view.popup.close();
          sketchViewModel.create("polygon");
        // add the clear selection button the view
        //view.ui.add("clear-selection", "top-left");
        //document.getElementById("clear-selection").addEventListener("click", () => {
          //featureTable.clearSelection();
          //featureTable.filterGeometry = null;
          //polygonGraphicsLayer.removeAll();
        // create a new sketch view model set its layer
        const sketchViewModel = new SketchViewModel({
          view: view,
          layer: polygonGraphicsLayer
        // Once user is done drawing a rectangle on the map
        // use the rectangle to select features on the map and table
        sketchViewModel.on("create", async (event) => {
          if (event.state === "complete") {
            // this polygon will be used to query features that intersect it
            const geometries = polygonGraphicsLayer.graphics.map(function(graphic){
              return graphic.geometry
            const queryGeometry = await geometryEngineAsync.union(geometries.toArray());
            selectFeatures(queryGeometry);
        // This function is called when user completes drawing a rectangle
        // on the map. Use the rectangle to select features in the layer and table
        function selectFeatures(geometry) {
          if (csvLayerView) {
            // create a query and set its geometry parameter to the
            // rectangle that was drawn on the view
            const query = {
              geometry: geometry,
              outFields: ["*"]
            // query graphics from the csv layer view. Geometry set for the query
            // can be polygon for point features and only intersecting geometries are returned
            csvLayerView.queryFeatures(query)
              .then((results) => {
                //const raro = [];
                if (results.features.length === 0) {
                  clearSelection();
                } else {
                  // მონიშნული ობიექტებისთვის მონაცემების წამოღება და ცხრილში ასახვა
                  results.features.forEach((feature)=>{
                    var tablemili = document.getElementById("tablemili");
                    newRow = tablemili.insertRow(tablemili.length),
                    cell1 = newRow.insertCell(0),
                    cell2 = newRow.insertCell(1),
                    cell3 = newRow.insertCell(2),
                    cell4 = newRow.insertCell(3),
                    cell5 = newRow.insertCell(4),
                    cell1.innerHTML = feature.attributes["milis_ID"];
                    cell2.innerHTML = feature.attributes["diametri"];
                    cell3.innerHTML = feature.attributes["dasaxeleba"];
                    cell4.innerHTML = feature.attributes["masala"];
                    cell5.innerHTML = feature.attributes["qselis_kategoria"];
        function errorCallback(error) {
          console.log("error happened:", error.message);
BlakeTerhune
Sorry if I'm misunderstanding, but can you loop over all your layers to do the query on line 57 in selectFeatures()?
map.allLayers.forEach(layer => {
    layer.queryFeatures(query)
        // do something with query results
BlakeTerhune
Thanks, but it does not work form me. I took another way to solve my issue. Thanks again.
BlakeTerhune
Glad you got it figured out, @Vakhtang_Zubiashvili. Can you post the solution to help other people with a similar problem?
