select marker symbol and change it dynamically
2347
03-31-2020 12:36 AM
rsharma
Query: How to change marker symbol dynamically programatically on graphics layer
rsharma
Hi I tried to change it by accessing its url.
 point_url = cloneGra.symbol.__accessor__.store._values.url;
and tried to change the symbol point_url in l while saving that marker, but it do not change.????
Do anyone know how to change symbol of individual marker
1 when we click on that marker,
2 define a marker type in textbox  save it and
3 change its symbol.
 var pointurl = funurl(mtype);
        point_url.url = pointurl;
        console.log(point_url.url);
It return perfect url but do not chnge marker symbol instantly i have to zoom in or zoomout  that map then the markers change???
Plus when i again change the same marker it do not chnage symbol
rsharma
Hi after so many efforts my markersymbol changed but it only changed when i zoom in or out map after that. i called my event in view.when and in require function but it do not change instantly.
Is their any other way to do it.
Thanks in advance, this is my code below
 point_url = cloneGra.symbol.__accessor__.store._values;
                    //save marker button
           jQuery('#main').on('click','.savemarker',function(e){
              var points_arr=[];
              var markertype = jQuery(this).parents().find('.dropdownbtn').html();
              var comment = jQuery(this).parents().find('.write_comment').val();
              var tempoint = changedMarkerSymbol(markertype);//passing type of marker to this function
                point_url.url = tempoint;//tempoint contain new url
              points_arr={'x' : point_x_coordinate , 'y' : point_y_coordinate};
                 jQuery.ajax({
                                 //send ajax call to save data
                                    success: function(data){
            view.popup.close();
            });//End Save marker
RobertScheitlin__GISP
Rajni,
  The simple solution is to remove that graphic and re-add it with the new symbology.
rsharma
Hi Robert Scheitlin, GISP
I am changing marker symbol url here
//This is tempgraphics function
  markerGL.add(cloneGra);
            }//End If
           }//End addTempGraphics
//On button save click
var tempoint = changedMarkerSymbol(markertype);//passing type of marker to this function and it return new symbol url
That not what I suggested
