Select layer to use for Closest Facility Route
1719
11-14-2014 09:05 AM
CraigLinn
I am trying to figure out the best way to route to closest facility based on radio button selection. The default routes to squares but I would like to choose between either circles or squares via radio button selection.
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Closest Facilities</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
  <style>
    body,html,#main{margin:0;padding:0;height:100%;width:100%;}
    .panel {
      border-radius: 6px;
      box-shadow: 0px 6px 3px -3px #888;
      border: 2px solid #86942A;
      margin: 5px;
        #metac {        position: absolute;
            left: 20px;       bottom: 62px;
            width: 10em;           height: 5em;
            z-index: 40;            background: #fff;
            color: #777;            padding: 5px;
            border: 2px solid #686;            -webkit-border-radius: 5px;
            -moz-border-radius: 5px;            border-radius: 5px;
            font-family: arial;        font-size: 0.9em;
            #metac h3 {
                color: #666;
                font-size: 1.1em;
                padding: 0px;
                margin: 0px;
                display: inline-block;
  </style>
  <script src="http://js.arcgis.com/3.11/"></script>
  <script>
    var map, params;
    require([
      "dojo/dom",
      "dojo/_base/array",
      "esri/Color",
      "dojo/parser",
      "dijit/registry",
      "esri/urlUtils",
      "esri/map",
      "esri/lang",
      "esri/graphic",
      "esri/InfoTemplate",
      "esri/layers/GraphicsLayer",
      "esri/renderers/SimpleRenderer",
      "esri/geometry/Point",
      "esri/tasks/FeatureSet",
      "esri/tasks/ClosestFacilityTask",
      "esri/tasks/ClosestFacilityParameters",
      "esri/symbols/SimpleMarkerSymbol",
      "esri/symbols/SimpleLineSymbol",
            "dijit/form/ComboBox",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane"
    ], function(
      dom, array, Color, parser, registry,
      urlUtils, Map, esriLang, Graphic, InfoTemplate, GraphicsLayer, SimpleRenderer,
      Point, FeatureSet,
      ClosestFacilityTask, ClosestFacilityParameters,
      SimpleMarkerSymbol, SimpleLineSymbol
      var incidentsGraphicsLayer, routeGraphicLayer, closestFacilityTask;
      parser.parse();
      urlUtils.addProxyRule({
        urlPrefix: "route.arcgis.com",
        proxyUrl: "/sproxy/"
      map = new Map("map", {
        basemap: "streets",
        center: [-122.4, 37.785],
        zoom: 14,
        showInfoWindowOnClick: false
      map.on("click", mapClickHandler);
      params = new ClosestFacilityParameters();
      params.impedenceAttribute= "Miles";
      params.defaultCutoff= 7.0;
      params.returnIncidents=false;
      params.returnRoutes=true;
      params.returnDirections=true;
      map.on("load", function(evtObj) {
        var map = evtObj.target;
        var facilityPointSymbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_SQUARE,
          20,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_SOLID,
            new Color([89,95,35]), 2
          new Color([130,159,83,0.40])
        var incidentPointSymbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_DIAMOND,
          16,
            new Color([200,100,200]), 2
          new Color([200,100,200,0.9])
        incidentsGraphicsLayer = new GraphicsLayer();
        var incidentsRenderer = new SimpleRenderer(incidentPointSymbol);
        incidentsGraphicsLayer.setRenderer(incidentsRenderer);
        map.addLayer(incidentsGraphicsLayer);
        routeGraphicLayer = new GraphicsLayer();
        var routePolylineSymbol = new SimpleLineSymbol(
          new Color([250,0,0]),
          4.0
        var routeRenderer = new SimpleRenderer(routePolylineSymbol);
        routeGraphicLayer.setRenderer(routeRenderer);
        map.addLayer(routeGraphicLayer);
        var facilitiesGraphicsLayer = new GraphicsLayer();
        var facilityRenderer = new SimpleRenderer(facilityPointSymbol);
        facilitiesGraphicsLayer.setRenderer(facilityRenderer);
        map.addLayer(facilitiesGraphicsLayer);
        facilitiesGraphicsLayer.add(new Graphic(new Point(-13625960,4549921,map.spatialReference)));
        facilitiesGraphicsLayer.add(new Graphic(new Point(-13626184,4549247,map.spatialReference)));
        facilitiesGraphicsLayer.add(new Graphic(new Point(-13626477,4549415,map.spatialReference)));
        facilitiesGraphicsLayer.add(new Graphic(new Point(-13624374,4548254,map.spatialReference)));
        facilitiesGraphicsLayer.add(new Graphic(new Point(-13624891,4548565,map.spatialReference)));
        var facilities = new FeatureSet();
        facilities.features = facilitiesGraphicsLayer.graphics;
        params.facilities = facilities;
        params.outSpatialReference = map.spatialReference;
//////////////NEW Point Symbols  //////////
        var facilityNEWPointSymbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_CIRCLE,
          15,
            new Color([250,95,35]), 2
          new Color([130,250,83,0.40])
        var facilitiesNEWGraphicsLayer = new GraphicsLayer();
        var facilityNEWRenderer = new SimpleRenderer(facilityNEWPointSymbol);
        facilitiesNEWGraphicsLayer.setRenderer(facilityNEWRenderer);
        map.addLayer(facilitiesNEWGraphicsLayer);
        facilitiesNEWGraphicsLayer.add(new Graphic(new Point(-13625750,4549721,map.spatialReference)));
        facilitiesNEWGraphicsLayer.add(new Graphic(new Point(-13626194,4549547,map.spatialReference)));
        facilitiesNEWGraphicsLayer.add(new Graphic(new Point(-13626487,4549215,map.spatialReference)));
        facilitiesNEWGraphicsLayer.add(new Graphic(new Point(-13625375,4549459,map.spatialReference)));
        facilitiesNEWGraphicsLayer.add(new Graphic(new Point(-13624364,4548554,map.spatialReference)));
        var facilitiesNEW = new FeatureSet();
        facilitiesNEW.features = facilitiesNEWGraphicsLayer.graphics;
/////////////// END NEW POINT SYMBOL
      closestFacilityTask = new ClosestFacilityTask("http://route.arcgis.com/arcgis/rest/services/World/ClosestFacility/NAServer/ClosestFacility_World");
      registry.byId("numLocations").on("change", function() {
        params.defaultTargetFacilityCount = this.value;
        clearGraphics();
      function clearGraphics() {
        //clear graphics
        dom.byId("directionsDiv").innerHTML= "";
        map.graphics.clear();
        routeGraphicLayer.clear();
        incidentsGraphicsLayer.clear();
      function mapClickHandler(evt) {
        clearGraphics();
        var inPoint = new Point(evt.mapPoint.x, evt.mapPoint.y, map.spatialReference);
        var location = new Graphic(inPoint);
        incidentsGraphicsLayer.add(location);
        var features = [];
        features.push(location);
        var incidents = new FeatureSet();
        incidents.features = features;
        params.incidents = incidents;
        map.graphics.enableMouseEvents();
        routeGraphicLayer.on("mouse-over", function(evt){
          //clear existing directions and highlight symbol
          dom.byId("directionsDiv").innerHTML= "Hover over the route to view directions";
          var highlightSymbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0,255,255],0.25), 4.5);
          var highlightGraphic = new Graphic(evt.graphic.geometry,highlightSymbol);
          map.graphics.add(highlightGraphic);
          dom.byId("directionsDiv").innerHTML = esriLang.substitute(evt.graphic.attributes,"${*}");
        //solve
        closestFacilityTask.solve(params, function(solveResult){
          array.forEach(solveResult.routes, function(route, index){
            //build an array of route info
            var attr = array.map(solveResult.directions[index].features, function(feature){
              return feature.attributes.text;
            var infoTemplate = new InfoTemplate("Attributes", "${*}");
            route.setInfoTemplate(infoTemplate);
            route.setAttributes(attr);
            routeGraphicLayer.add(route);
            dom.byId("directionsDiv").innerHTML = "Hover over the route to view directions";
          //display any messages
          if(solveResult.messages.length > 0){
            dom.byId("directionsDiv").innerHTML = "<b>Error:</b> " + solveResult.messages[0];
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit/layout/BorderContainer"
       data-dojo-props="design:'headline', gutters:false"
       style="width:100%;height:100%;margin:0px;">
    <div id="map"
         data-dojo-type="dijit/layout/ContentPane"
         data-dojo-props="region:'center'" class="panel">
          <div id="metac"><h3>Layers</h3>
  <br>
  <form >
  <input type="radio" id="radCurrent" name="rbPoints" value="" checked>Current (Squares)<br>
  <input type="radio" id="radNew" name="rbPoints" value="">New (Circles)<br>
  </form>
  </div>
    </div>
    <div id="directions"
         data-dojo-props="region:'bottom'" class="panel"
         style="height:250px;">
      <b>Click the map to find routes for the
      <select id="numLocations" name="numLocations" data-dojo-type="dijit/form/ComboBox" value="1" style="width:60px;">
          <option selected="selected">1</option>
          <option>2</option>
          <option>3</option>
          <option>4</option>
          <option>5</option>
      </select> closest facilities to the input point.</b>
      <div id="directionsDiv"></div>
    </div>
</div>
</body>
</html>
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Craig,
You can use an IF statement to check which radio button is checked.  Which ever is checked, you can pass the correct facilities:
if(dojo.byId("radCurrent").checked){
if(dojo.byId("radNew").checked){
    params.facilities = facilitiesNEW;
Attached is an example.
JakeSkinner
Hi Craig,
CraigLinn
Thanks!!
