Select from layer to buffer from checkbox and then buffer it.
5085
10
07-11-2016 10:54 PM
AditiRoy1
Hello, Everyone. I am stuck in the code. I have list of layers in a dynamic layer checkbox and i want to select the layers to buffer whose result will be shown into the combobox. I am posting the code below. Please help. Thanks in advance.
-aditi
<!DOCTYPE HTML PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the
      samples on iOS devices-->
    <!--<script src="//ajax.googleapis.com/ajax/libs/dojo/1.10.4/dojo/dojo.js"></script>
    <link rel="stylesheet" type="text/css" href="https://community.esri.com//ajax.googleapis.com/ajax/libs/dojo/1.10.4/dojo/resources/dojo.css" />
    <link rel="stylesheet" type="text/css" href="https://community.esri.com//ajax.googleapis.com/ajax/libs/dojo/1.10.4/dijit/themes/tundra/tundra.css" />-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
    <title>Ground Water</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.15/dojo/resources/dojo.css" />
    <link rel="stylesheet" href="http://js.arcgis.com/3.15/dijit/themes/claro/claro.css" />
    <link rel="stylesheet" href="http://js.arcgis.com/3.15/dgrid/css/dgrid.css" />
    <link rel="stylesheet" href="http://js.arcgis.com/3.15/esri/css/esri.css" />
    <style type="text/css">
        html,
        body,
        #map {
            padding: 0;
            margin: 0;
            height: 100%;
        #rightPane {
            padding: 0;
            width: 420px;
            font-family: "Verdana";
            font-size: "4";
        .details {
            font-size: 14px;
            font-weight: 600;
            padding-bottom: 20px;
        #button1 {
            margin: 2px;
            cursor: pointer;
        #search {
            display: block;
            position: absolute;
            z-index: 2;
            top: 20px;
            left: 60px;
        #header {
            border: solid #00ffff 3px;
            background-color: #00ffff;
        #titlePane {
            width: 240px;
        .esriScalebar {
            padding: 20px 20px;
        #map {
            padding: 0;
        .dgrid {
            border: none;
            height: 100%;
        .dgrid-column-0 {
            width: 35px;
        .dgrid-row-odd {
            background: #FFFDF3;
        td div img:hover {
            cursor: pointer;
        #titlePane {
            width: 240px;
        .claro .dijitTitlePaneTitle {
            background: #fff;
            font-weight: 600;
            border: none;
            border-bottom: solid 1px #29201A;
            border-top: solid 1px #29201A;
        .claro .dijitTitlePaneTitleHover {
            background: #eee;
        .claro .dijitTitlePaneTitleActive {
            background: #808775;
        .claro .dijitTitlePaneContentOuter {
            border-right: none;
            border-bottom: none;
            border-left: none;
    </style>
    <script src="http://js.arcgis.com/3.15/"></script>
    <script>
        var map, geocoder, grid, tb, hospital, hydrant;
        var  cred = "esri_jsapi_id_manager_data"; // cookie/local storage name
        var showDialog2, myDialog2;
        var layer, visibleLayerIds = [];
        require([
            "dojo/_base/unload",
    "dojo/cookie",
    "dojo/json",
    "dojo/parser", "esri/config", "esri/IdentityManager",
            "esri/map", 'esri/dijit/Basemap',
           'esri/dijit/BasemapLayer',
            "esri/InfoTemplate",
            "esri/dijit/Geocoder",
            "esri/graphic",
            "dojo/query",
            "esri/config",
            "esri/geometry/normalizeUtils",
            "esri/tasks/GeometryService",
            "esri/tasks/BufferParameters",
            "esri/toolbars/draw",
            "dijit/registry",
            "esri/symbols/SimpleLineSymbol",
            "esri/symbols/SimpleFillSymbol",
            "esri/symbols/SimpleMarkerSymbol",
            "esri/renderers/SimpleRenderer",
            "esri/dijit/Measurement",
            "esri/layers/FeatureLayer",
            "esri/layers/ArcGISDynamicMapServiceLayer",
             "dojo/dom-construct",
            "dijit/form/CheckBox",
            "esri/geometry/screenUtils",
            "esri/dijit/PopupTemplate",
            "esri/request",
            "esri/tasks/query",
            "esri/geometry/Point",
            "esri/graphic",
            "esri/symbols/PictureMarkerSymbol",
            "dojo/on",
            "dojo/_base/array",
            "dojo/promise/all",
            "esri/Color",
            "dojo/_base/array",
            "dgrid/OnDemandGrid", "dgrid/Selection", "dojo/store/Memory",
            "dijit/form/Button",
            "dojo/parser", "dojo/_base/declare", "dojo/dom", "dojox/grid/DataGrid", "dojo/data/ItemFileReadStore",
            "dijit/TitlePane", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/layout/AccordionContainer",
            "dijit/Dialog", "dijit/form/TextBox", "dijit/DialogUnderlay", "dijit/form/ComboBox", "esri/layers/ImageParameters",
            "dojo/domReady!"
        ], function (baseUnload,
    cookie,
    JSON,
    parser, esriConfig, esriId,
          Map, Basemap, BasemapLayer,
          InfoTemplate,
          Geocoder,
          Graphic, query, esriConfig, normalizeUtils, GeometryService, BufferParameters, Draw, registry, SimpleLineSymbol, SimpleFillSymbol, SimpleMarkerSymbol,
          SimpleRenderer,
          Measurement,
          FeatureLayer,
          ArcGISDynamicMapServiceLayer,
           domConstruct,
        CheckBox,
         screenUtils,
          PopupTemplate,
          esriRequest,
          Query,
          Point,
          Graphic,
          PictureMarkerSymbol,
          on,
          array,
          All,
          Color,
          arrayUtils,
          Grid, Selection, Memory,
          Button,
          parser, declare, dom, DataGrid, ItemFileReadStore, Dialog, TextBox, DialogUnderlay, ComboBox,ImageParameters
            parser.parse();
            esriConfig.defaults.geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
            esriConfig.defaults.io.proxyUrl = "/proxy/";
            esriConfig.defaults.io.alwaysUseProxy = false;
            // store credentials/serverInfos before the page unloads
            baseUnload.addOnUnload(storeCredentials);
            // look for credentials in local storage
            loadCredentials();
            parser.parse();
            esriConfig.defaults.io.proxyUrl = "proxy.ashx";
            on(dom.byId("clearGraphics"), "click", function () {
                if (map) {
                    map.graphics.clear();
            var featureLayer;
            map = new Map("map", {
                basemap: "topo",
                center: [72.2763, 26.3855],
                zoom: 7
            map.on("load", initOperationalLayer);
            map.on("load", initToolbar);
            var BaseMap = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/GWD/GWDBASE/MapServer/0",
                mode: FeatureLayer.MODE_ONDEMAND,
                outFields: ["*"]
            map.addLayer(BaseMap);
            var BaseMap1 = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/GWD/GWDBASE/MapServer/1",
                outFields: ["*"]
            map.addLayer(BaseMap1);
            var BaseMap2 = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/GWD/GWDBASE/MapServer/2",
                outFields: ["*"]
            map.addLayer(BaseMap2);
            var BaseMap3 = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/GWD/GWDBASE/MapServer/3",
                outFields: ["*"]
            map.addLayer(BaseMap3);
            var BaseMap4 = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/GWD/GWDBASE/MapServer/4",
                outFields: ["*"]
            map.addLayer(BaseMap4);
            var BaseMap5 = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/GWD/GWDBASE/MapServer/5",
                outFields: ["*"]
            map.addLayer(BaseMap5);
            //add the secure service - token is required
            var secureLayer = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/Common/ADMIN/MapServer/0",
                  outFields: ["*"]
            var secureLayer1 = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/Common/ADMIN/MapServer/1",
                  outFields: ["*"]
            var secureLayer2 = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/Common/ADMIN/MapServer/2",
                  outFields: ["*"]
            var secureLayer3 = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/Common/ADMIN/MapServer/3",
                  outFields: ["*"]
            var secureLayer4 = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/Common/ADMIN/MapServer/4",
                  outFields: ["*"]
            var secureLayer5 = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/Common/ADMIN/MapServer/5",
                  outFields: ["*"]
            var secureLayer6 = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/Common/ADMIN/MapServer/6",
                  outFields: ["*"]
            var secureLayer7 = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/Common/ADMIN/MapServer/7",
                  outFields: ["*"]
            var secureLayer8 = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/Common/ADMIN/MapServer/8",
                  outFields: ["*"]
            map.addLayers([secureLayer8, secureLayer7, secureLayer6, secureLayer5, secureLayer4, secureLayer3, secureLayer2, secureLayer1, secureLayer]);
            // adding check box
            map.on("layers-add-result", function (evt) {
                var layerInfo = array.map(evt.layers, function (layer,
                index) {
                    return {
                        layer: layer.layer,
                        title: layer.layer.name
                array.forEach(layerInfo, function (layer) {
                    var layerName = layer.title;
                    if (layerName == undefined) {
                        layerName = secureLayer8;
                    var checkBox = new CheckBox({
                        name: "checkBox" + layer.layer.id,
                        value: layer.layer.id,
                        checked: layer.layer.visible,
                        onChange: function (evt) {
                            var clayer = map.getLayer(this.value);
                            clayer.setVisibility(!clayer.visible);
                            this.checked = clayer.visible;
                    domConstruct.place(checkBox.domNode, "t",
                        "after");
                    var checkLabel = domConstruct.create('label', {
                        'for': checkBox.name,
                        innerHTML: layerName
                    }, checkBox.domNode, "after");
                    domConstruct.place("<br />", checkLabel,
                        "after");
            function initOperationalLayer() {
                //Layer that is in Lat, Long Spatial reference 102100
                var infoTemplate = new InfoTemplate();
                hydrant = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/Common/ADMIN/MapServer/3", {
                    outFields: ["*"],
                    infoTemplate: infoTemplate
                //Layer that is NAD83 / UTM zone 15 N Spatial Reference 26915
                hospital = new FeatureLayer("http://gistest1.rajasthan.gov.in/rajasthan/rest/services/Common/ADMIN/MapServer/4", {
                    outFields: ["*"],
                var outline = new SimpleLineSymbol()
                  .setColor(Color.fromHex('#fff'));
                var sym = new SimpleFillSymbol()
                  .setColor(new Color([212, 212, 210, 0.3]))
                  .setOutline(outline);
                var renderer = new SimpleRenderer(sym);
                map.addLayer(hydrant);
                map.addLayer(hospital);
            function initToolbar(evtObj) {
                tb = new Draw(evtObj.map);
                tb.on("draw-end", doBuffer);
                //click handler for the draw tool buttons
                query(".tool").on("click", function (evt) {
                    if (tb) {
                        tb.activate(evt.target.id);
            function doBuffer(evtObj) {
                tb.deactivate();
                var geometry = evtObj.geometry,
                  symbol;
                switch (geometry.type) {
                    case "point":
                        symbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 10, new SimpleLineSymbol(SimpleMarkerSymbol.STYLE_SOLID, new Color([255, 0, 0]), 1), new Color([0, 255, 0, 0.25]));
                        break;
                    case "polyline":
                        symbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASH, new Color([255, 0, 0]), 1);
                        break;
                    case "polygon":
                        symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_NONE, new SimpleLineSymbol(SimpleLineSymbol.STYLE_DASHDOT, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]));
                        break;
                var graphic = new Graphic(geometry, symbol);
                map.graphics.add(graphic);
                //setup the buffer parameters
                var params = new BufferParameters();
                params.distances = [dom.byId("distance").value];
                params.outSpatialReference = map.spatialReference;
                params.unit = GeometryService[dom.byId("unit").value];
                //normalize the geometry
                normalizeUtils.normalizeCentralMeridian([geometry]).then(function (normalizedGeometries) {
                    var normalizedGeometry = normalizedGeometries[0];
                    if (normalizedGeometry.type === "point") {
                        //if geometry is a polygon then simplify polygon.  This will make the user drawn polygon topologically correct.
                        esriConfig.defaults.geometryService.simplify([normalizedGeometry], function (geometries) {
                            params.geometries = geometries;
                            esriConfig.defaults.geometryService.buffer(params, showBuffer);
                    } else {
                        params.geometries = [normalizedGeometry];
                        esriConfig.defaults.geometryService.buffer(params, showResults);
            function showBuffer(bufferedGeometries) {
                var symbol = new SimpleFillSymbol(
                  SimpleFillSymbol.STYLE_SOLID,
                    SimpleLineSymbol.STYLE_SOLID,
                    new Color([255, 0, 0, 0.65]), 2
                  new Color([255, 0, 0, 0.35])
                arrayUtils.forEach(bufferedGeometries, function (geometry) {
            on(esriConfig.defaults.geometryService, "buffer-complete", function (Geom) {
                queryMapService(Geom)
            function queryMapService(Geom) {
                var promises = [];
                var query = new Query();
                query.returnGeometry = false;
                query.outFields = ["*"];
                query.geometry = Geom.geometries[0];
                promises.push(hydrant.selectFeatures(query, FeatureLayer.SELECTION_NEW));
                promises.push(hospital.selectFeatures(query, FeatureLayer.SELECTION_NEW));
                var allPromises = new All(promises);
                allPromises.then(function (r) {
                    showResults(r);
            function showResults(results) {
                console.log(results);
                var items = arrayUtils.map(results, function (result) {
                    return result;
                var allItems = [];
                arrayUtils.map(items[0], function (item) {
                    allItems.push(item.attributes);
                arrayUtils.map(items[1], function (item) {
                var data = {
                    identifier: "OBJECTID", //This field needs to have unique values
                    label: "OBJECTID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
                    items: allItems
                //Create data store and bind to grid.
                store = new ItemFileReadStore({
                    data: data
                var grid = registry.byId("grid");
                grid.setStore(store);
                grid.on("rowclick", onRowClickHandler);
            function onRowClickHandler(evt) {
                var clickedObjectf = evt.grid.getItem(evt.rowIndex).OBJECTID;
                var selectedObjectf;
                var distance = 50;
                dojo.forEach(hydrant.graphics, function (graphicf) {
                    if ((graphicf.attributes) && graphicf.attributes.OBJECTID === clickedObjectf) {
                        selectedObjectf = graphicf;
                        return;
                dojo.forEach(hospital.graphics, function (graphicf) {
                        return;
                if (selectedObjectf.geometry.declaredClass == 'esri.geometry.Point') {
                    var PointExtent = new esri.geometry.Extent({
                        "xmin": selectedObjectf.geometry.x - distance,
                        "ymin": selectedObjectf.geometry.y - distance,
                        "xmax": selectedObjectf.geometry.x + distance,
                        "ymax": selectedObjectf.geometry.y + distance,
                        "spatialReference": {
                            "wkid": 102100
                    map.setExtent(PointExtent);
            function showLocation(evt) {
                var point = evt.result.feature.geometry;
                var symbol = new SimpleMarkerSymbol()
                  .setStyle("square")
                  .setColor(new Color([255, 0, 0, 0.5]));
                var graphic = new Graphic(point, symbol);
                map.infoWindow.setTitle("Search Result");
                map.infoWindow.setContent(evt.result.name);
                map.infoWindow.show(evt.result.feature.geometry);
            function loadCredentials() {
                var idJson, idObject;
                if (supports_local_storage()) {
                    // read from local storage
                    idJson = window.localStorage.getItem(cred);
                else {
                    // read from a cookie
                    idJson = cookie(cred);
                if (idJson && idJson != "null" && idJson.length > 4) {
                    idObject = JSON.parse(idJson);
                    esriId.initialize(idObject);
                else {
                    // console.log("didn't find anything to load :(");
            function storeCredentials() {
                // make sure there are some credentials to persist
                if (esriId.credentials.length === 0) {
                    return;
                // serialize the ID manager state to a string
                var idString = JSON.stringify(esriId.toJson());
                // store it client side
                    // use local storage
                    window.localStorage.setItem(cred, idString);
                    // console.log("wrote to local storage");
                else {
                    // use a cookie
                    cookie(cred, idString, { expires: 72000000000000000 });
                    // console.log("wrote a cookie :-/");
            function supports_local_storage() {
                try {
                    return "localStorage" in window && window["localStorage"] !== null;
                } catch (e) {
                    return false;
    </script>
</head>
<body class="claro">
    <div id="main" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width:100%; height:100%;">
        <div id="header" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'">
            <center><font size="4"><strong>Ground Water</strong></font></center>
            <button data-dojo-type="dijit/form/Button" style="float:right" onclick="showDialog();"><b>Search Assets</b></button>
        </div>
         <div id="map" class="shadow roundedCorners" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'">
            <div style="position:absolute; right:20px; top:10px; z-Index:999;">
            </div>
            <div id="SearchAssets" >
                <span style="padding: 10px 0;">Click to toggle each layer on or off</span>
                   <div id="t" style="padding: 2px 2px;"></div>
       <br />
                <div class="details">Pick a tool and draw on the map. The drawn graphic will be buffered based on the specified parameters.</div>
                <div><b>Buffer Parameters</b></div>
                Distance:
                <input type="text" id="distance" size="5" value="25" />
                <select id="unit" style="width:100px;">
                    <option value="UNIT_STATUTE_MILE">Miles</option>
                    <option value="UNIT_FOOT">Feet</option>
                    <option value="UNIT_KILOMETER">Kilometers</option>
                    <option value="UNIT_METER">Meters</option>
                    <option value="UNIT_NAUTICAL_MILE">Nautical Miles</option>
                    <option value="UNIT_US_NAUTICAL_MILE">US Nautical Miles</option>
                    <option value="UNIT_DEGREE">Degrees</option>
                </select>
                <br /> <br /><br />
                <button type="button"  onclick="point"  class="tool" id="point">Click On The Map</button>
                <button type="button" id="clearGraphics">Clear Graphics</button>
                <br />
                <br /><hr />
                <table data-dojo-type="dojox/grid/DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'1', rowSelector:'30px'">
                    <thead>
                        <tr>
                            <th width=40 field="OBJECTID">ID</th>
                            <th width=180 field="DISTRICT_NAME_EN">NAME</th>
                        </tr>
                    </thead>
                </table>
                <hr />
                <br />
            </div>
        </div>
    </div>
    <script type="text/javascript">
        require(["dijit/Dialog", "dijit/DialogUnderlay", "dojo/dom", "dojo/domReady!"], function (Dialog, DialogUnderlay, dom) {
            myDialog = new Dialog({
                title: "Search Assets",
                content: dom.byId('SearchAssets'),
                style: "width: 300px"
            showDialog = function () {
                myDialog.show().then(function () {
                    DialogUnderlay.hide()
                    DialogUnderlay._singleton.bgIframe = {
                        destroy: function () {
    </script>
</body>
</html>
RobertScheitlin__GISP
Aditi,
  Since we do not have access to your data can you tell use with your code is failing at (in your browsers web console is there a line number it fails at)?
AditiRoy1
Dear Sir, as i am providing you a new code with some other data. Hope it will help. And thank you once again.
<!DOCTYPE>
<html>
<head>
        html,
        body,
        #map {
            padding: 0;
            margin: 0;
            height: 100%;
        #rightPane {
            padding: 0;
            width: 420px;
            font-size: "4";
        .details {
            font-size: 14px;
            font-weight: 600;
        #button1 {
            margin: 2px;
            cursor: pointer;
        #search {
            display: block;
            position: absolute;
            z-index: 2;
            top: 20px;
            left: 60px;
        #header {
        #titlePane {
            width: 240px;
        .esriScalebar {
            padding: 20px 20px;
        #map {
            padding: 0;
        .dgrid {
            border: none;
            height: 100%;
        .dgrid-column-0 {
            width: 35px;
        .dgrid-row-odd {
        td div img:hover {
            cursor: pointer;
        #titlePane {
            width: 240px;
            background: #fff;
            font-weight: 600;
            border: none;
            background: #eee;
            border-right: none;
            border-left: none;
    </style>
    <script>
        require([
    "dojo/cookie",
    "dojo/json",
            "esri/graphic",
            "dojo/query",
            "esri/config",
            "dijit/registry",
            "esri/request",
            "esri/tasks/query",
            "esri/graphic",
            "dojo/on",
            "dojo/_base/array",
            "dojo/promise/all",
            "esri/Color",
            "dojo/_base/array",
            "dojo/domReady!"
    cookie,
    JSON,
          InfoTemplate,
          Geocoder,
          SimpleRenderer,
          Measurement,
          FeatureLayer,
           domConstruct,
        CheckBox,
         screenUtils,
          PopupTemplate,
          esriRequest,
          Query,
          Point,
          Graphic,
          on,
          array,
          All,
          Color,
          arrayUtils,
          Button,
          parser, declare, dom, DataGrid, ItemFileReadStore, Dialog, TextBox, DialogUnderlay, ComboBox, ImageParameters
            parser.parse();
            loadCredentials();
            parser.parse();
                if (map) {
            var featureLayer;
                basemap: "topo",
                center: [-120.275, 47.485],
                zoom: 6
            map.addLayers([secureLayer, secureLayer1]);
            // adding check box
                index) {
                    return {
                        layer: layer.layer,
                        layerName = secureLayer1;
                        "after");
                        "after");
                hydrant = new FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...", {
                    outFields: ["*"],
                hospital = new FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/Map...", {
                    outFields: ["*"],
                    if (tb) {
                tb.deactivate();
                  symbol;
                    case "point":
                        break;
                    case "polyline":
                        break;
                    case "polygon":
                        break;
                    } else {
                var promises = [];
                    showResults(r);
                    return result;
                var allItems = [];
                var data = {
                    identifier: "FID", //This field needs to have unique values
                    label: "FID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
                    items: allItems
                    data: data
                var distance = 50;
                        return;
                        return;
                            "wkid": 102100
                  .setStyle("square")
                else {
                else {
                    return;
                else {
                    // use a cookie
                try {
                } catch (e) {
                    return false;
    </script>
</head>
        </div>
            </div>
            <div id="SearchAssets">
                <br />
                Distance:
                </select>
                <br /> <br /><br />
                <br />
                <br /><hr />
                    <thead>
                        <tr>
                            <th width=40 field="FID">ID</th>
                            <th width=180 field="Shape">SHAPE</th>
                        </tr>
                    </thead>
                </table>
                <hr />
                <br />
            </div>
        </div>
    </div>
    </script>
</body>
</html>
Aditi,
  Here is the code working. There was to many thing I fixed to outline them for you so you will just have to compare my corrected code to yours:
<!DOCTYPE>
<html>
<head>
        html,
        body,
        #map {
            padding: 0;
            margin: 0;
            height: 100%;
        #rightPane {
            padding: 0;
            width: 420px;
            font-size: "4";
        .details {
            font-size: 14px;
            font-weight: 600;
        #button1 {
            margin: 2px;
            cursor: pointer;
        #search {
            display: block;
            position: absolute;
            z-index: 2;
            top: 20px;
            left: 60px;
        #header {
        #titlePane {
            width: 240px;
        .esriScalebar {
            padding: 20px 20px;
        #map {
            padding: 0;
        .dgrid {
            border: none;
            height: 100%;
        .dgrid-column-0 {
            width: 35px;
        .dgrid-row-odd {
        td div img:hover {
            cursor: pointer;
        #titlePane {
            width: 240px;
            background: #fff;
            font-weight: 600;
            border: none;
            background: #eee;
            border-right: none;
            border-left: none;
    </style>
    <script>
        var myDialog;
        require([
            "dojo/_base/unload", "dojo/cookie", "dojo/json", "dojo/parser", "esri/config", "esri/IdentityManager", "dojo/_base/lang",
            "esri/map", 'esri/dijit/Basemap', 'esri/dijit/BasemapLayer',   "esri/InfoTemplate", "esri/dijit/Geocoder", "esri/geometry/Extent",
            "esri/graphic", "dojo/query", "esri/geometry/normalizeUtils", "esri/tasks/GeometryService", "esri/tasks/BufferParameters",
            "esri/toolbars/draw", "dijit/registry", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleMarkerSymbol",
            "esri/renderers/SimpleRenderer", "esri/dijit/Measurement", "esri/layers/FeatureLayer", "esri/layers/ArcGISDynamicMapServiceLayer",
            "dojo/dom-construct", "dijit/form/CheckBox", "esri/geometry/screenUtils", "esri/dijit/PopupTemplate", "esri/request", "esri/tasks/query",
            "esri/geometry/Point", "esri/graphic", "esri/symbols/PictureMarkerSymbol", "dojo/on", "dojo/_base/array", "dojo/promise/all",
            "esri/Color", "dgrid/OnDemandGrid", "dgrid/Selection", "dojo/store/Memory", "dijit/form/Button",
            "dojo/domReady!"
        ], function(
            baseUnload, cookie, JSON, parser, esriConfig, esriId, lang,
            Map, Basemap, BasemapLayer, InfoTemplate, Geocoder, Extent,
            Graphic, query, normalizeUtils, GeometryService, BufferParameters,
            SimpleRenderer, Measurement, FeatureLayer, ArcGISDynamicMapServiceLayer,
            domConstruct, CheckBox, screenUtils, PopupTemplate, esriRequest, Query,
            Point, Graphic, PictureMarkerSymbol, on, array, All,
            Color, Grid, Selection, Memory, Button,
            parser.parse();
            loadCredentials();
            var featureLayer;
                basemap: "topo",
                zoom: 6
            map.on("load", initEvents);
            //map.addLayers([secureLayer, secureLayer1]);
            // adding check box
            map.on("layers-add-result", function(evt) {
                var layerInfo = array.map(evt.layers, function(layer,
                    index) {
                    return {
                        layer: layer.layer,
                array.forEach(layerInfo, function(layer) {
                        onChange: function(evt) {
                        "after");
                        "after");
            function initEvents(){
              registry.byId("dialogBtn").on("click", function(){
                myDialog.show().then(function() {
                        destroy: function() {}
              on(dom.byId("clearGraphics"), "click", function() {
                  if (map) {
              console.info(registry.byId("toggleButton"));
                    outFields: ["*"],
                    outFields: ["*"],
                query(".tool").on("click", function(evt) {
                    if (tb) {
                tb.deactivate();
                    symbol;
                    case "point":
                        break;
                    case "polyline":
                        break;
                    case "polygon":
                        break;
                normalizeUtils.normalizeCentralMeridian([geometry]).then(function(normalizedGeometries) {
                        esriConfig.defaults.geometryService.simplify([normalizedGeometry], function(geometries) {
                    } else {
                array.forEach(bufferedGeometries, function(geometry) {
            on(esriConfig.defaults.geometryService, "buffer-complete", function(Geom) {
                var promises = [];
                allPromises.then(function(r) {
                    showResults(r);
                var items = array.map(results, function(result) {
                    return result;
                var allItems = [];
                array.map(items[0], function(item) {
                array.map(items[1], function(item) {
                var data = {
                    items: allItems
                    data: data
                var grid = registry.byId("resultsgrid");
                var clickedObjectf = evt.grid.getItem(evt.rowIndex).FID;
                console.info(clickedObjectf);
                var distance = 50;
                array.forEach(hydrant.graphics, function(graphicf) {
                    if ((graphicf.attributes) && graphicf.attributes.FID === clickedObjectf) {
                        return;
                array.forEach(hospital.graphics, function(graphicf) {
                        return;
                if ((selectedObjectf) && selectedObjectf.geometry.declaredClass == 'esri.geometry.Point') {
                    var PointExtent = new Extent({
                            "wkid": 102100
                    .setStyle("square")
                } else {
                } else {
                    return;
                } else {
                    // use a cookie
                try {
                } catch (e) {
                    return false;
    </script>
</head>
    <div id="main" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width:100%; height:100%;">
        <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
            <button data-dojo-type="dijit/form/Button" style="float:right" id="dialogBtn" type="button"><b>Search Assets</b></button>
        </div>
        <div id="map" class="shadow roundedCorners" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
            </div>
                <br />
                Distance:
                </select>
                <br />
                <br />
                <br />
                <br />
                <br />
                <hr />
                <table data-dojo-type="dojox/grid/DataGrid" id="resultsgrid" data-dojo-props="rowsPerPage:'1', rowSelector:'30px'">
                    <thead>
                        <tr>
                        </tr>
                    </thead>
                </table>
                <hr />
                <br />
            </div>
        </div>
    </div>
</body>
</html>
anjelinaponkerat
I tested your code, but I think there is a bug in it and don't work for me!
Anjelina,
   You have to start looking an the errors in the browsers web console. It probably says that you do not have the proxy url setup for the proper location on your machine.
anjelinaponkerat
Yes
What should  I do? Is it possible correct code?
Sure change the proxy url path to be the correct path on your machine.
anjelinaponkerat
Hi
I changed map service and feature service address to my localhost  also css and js address, but sample dont work. should change in these lines?:
If yes, how?
regards
anjelinaponkerat
I solved proxy problem. but I don't know what is the meaning of:"Click to toggle each layer on or off"? because there in not toggle and...  also  the table is empty(image 2).
this is preview of output:
buffer preview
(image2):
