Select features with buffer not working properly
3359
8
10-03-2014 10:25 AM
RyanSellman
I'm trying to incorporate an esri sample in my app, where the user clicks on the map, which creates a buffer and selects features within that buffer.  I can get the the buffer to work correctly and the selected features are drawing ok, however I'm trying to push the selected results to an enhanced datagrid and keep getting this error: "ReferenceError: array is not defined".  I feel like I'm missing something really small but can't figure it out.  Can anyone help??
Here's the code I am using:
var gridNF = new EnhancedGrid({
  structure : [
  {name: "UNAME", field : "UNAME"}
  plugins: {
  exporter: true,
  printer: true
  }, "divGrid");
  gridNF.startup();
  var outFieldsNF = ["UNAME"];
  var doesFeatureLayer = new FeatureLayer("http://summitgis.summitoh.net:6080/arcgis/rest/services/DOES_Mercator/MapServer/1",{
  outFields: ["*"],
  mode: FeatureLayer.MODE_ONDEMAND
  var symbol = new SimpleMarkerSymbol(
  SimpleMarkerSymbol.STYLE_CIRCLE,
  12,
  new SimpleLineSymbol(
  SimpleLineSymbol.STYLE_NULL,
  new Color([247, 34, 101, 0.9]),
  new Color([207, 34, 171, 0.5])
  doesFeatureLayer.setSelectionSymbol(symbol);
  map.addLayer(doesFeatureLayer);
  var circleSymb = new SimpleFillSymbol(
  SimpleFillSymbol.STYLE_NULL,
  SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
  new Color([105, 105, 105]),
  ), new Color([255, 255, 0, 0.25])
  var circle;
  var radius = parseInt(dom.byId("bufferDistance").value);
  map.on("click", function(evt){
  circle = new Circle({
  center: evt.mapPoint,
  geodesic: true,
  radius: radius,
  radiusUnit: "esriFeet"
  map.graphics.clear();
  //map.infoWindow.show();
  var graphic = new Graphic(circle, circleSymb);
  map.graphics.add(graphic);
  var query = new Query();
  query.geometry = circle.getExtent();
  doesFeatureLayer.queryFeatures(query, selectInBuffer);
  function selectInBuffer(response){
  var feature;
  var features = response.features;
  var inBuffer = [];
  for (var i = 0; i < features.length; i++) {
  feature = features
  if(circle.contains(feature.geometry)){
  inBuffer.push(feature.attributes[doesFeatureLayer.objectIdField]);
  query.objectIds = inBuffer;
  doesFeatureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(results){
  populateGrid(response);
  function populateGrid(results) {
  var gridData;
  dataNF = array.map(results.features, function(feature) {
  return {
  "UNAME" : feature.attributes[outFieldsNF[1]],
  var memStore = new ItemFileWriteStore({
  data : {
  identifier: 'OBJECTID',
  items: dataNF
  gridNF.setStore(memStore);
RyanSellman
Ok, I think I have it figured out, with your help of course.  In response to your last inquiry, I included the field "OBJECTID" (along with a few others) in the outFieldsNF variable:
var outFieldsNF = ["OBJECTID", "UNAME", "DRAWINGNUM", "INVERT", "STREET"]
and also, I included, "OBJECTID" here:
dataNF = arrayUtils.map(results.features, function(feature) {
  return {
  "OBJECTID" : feature.attributes[outFieldsNF[0]],
  "DRAWINGNUM" : feature.attributes[outFieldsNF[2]],
  "INVERT" : feature.attributes[outFieldsNF[3]],
  "STREET" : feature.attributes[outFieldsNF[4]]
along with those few extra fields.  These changes seem to have it fixed!
I really appreciate your help!
KenBuja
MVP Esteemed Contributor
Did you add the array module in your require? You'll need something like
require(["dojo/_base/array"], function (array) {}
RyanSellman
Yep!  Here's what I have in my require:
require([
                "dojo/parser",
                "esri/geometry/Extent",
                 "esri/geometry/Circle",
                 "dojo/store/Memory",
                 "dojo/data/ItemFileWriteStore",
                 "dgrid/OnDemandGrid",
                 "dojox/grid/EnhancedGrid",
                 "dojox/grid/enhanced/plugins/exporter/CSVWriter",
                 "dojox/grid/enhanced/plugins/Printer",
                 "dgrid/Selection",
                "esri/graphicsUtils",
                "esri/SpatialReference",
                "dojo/on", "dojo/dom",
                "dijit/registry",
                "esri/tasks/FindTask",
                "esri/tasks/FindParameters",
                "esri/map",
                "esri/layers/ArcGISDynamicMapServiceLayer",
                "esri/InfoTemplate",
                "dojo/dom-construct",
                "esri/dijit/Popup",
                "esri/tasks/IdentifyTask",
                "esri/tasks/IdentifyResult",
                "esri/tasks/IdentifyParameters",
                "esri/dijit/InfoWindow",
                "esri/dijit/HomeButton",
                "esri/layers/FeatureLayer",
                 "esri/toolbars/navigation",
                "esri/dijit/Legend",
                "esri/dijit/Print",
                "esri/dijit/BasemapToggle",
                "dojo/_base/array",
                "dijit/form/CheckBox",
                "dijit/form/NumberTextBox",
                "esri/dijit/BasemapGallery",
                "esri/dijit/Geocoder",
                "dojo/_base/Color",
                "esri/graphic",
                "esri/tasks/Geoprocessor",
                "esri/symbols/SimpleMarkerSymbol",
                "esri/geometry/screenUtils",
                "esri/dijit/Measurement",
                "esri/dijit/OverviewMap",
                "esri/dijit/Bookmarks",
                "esri/dijit/BasemapLayer",
                "esri/dijit/Basemap",
                "esri/dijit/BookmarkItem",
                "esri/units",
                "esri/geometry/Geometry",
                "esri/geometry/Point",
                "esri/geometry/Polyline",
                "esri/geometry/Polygon",
                "esri/dijit/Scalebar",
                "esri/dijit/AttributeInspector",
                "esri/symbols/SimpleLineSymbol",
                "dojo/query",
                "esri/symbols/SimpleFillSymbol",
                "esri/layers/ArcGISTiledMapServiceLayer",
                "esri/layers/ImageParameters",
                "esri/config",
                "esri/tasks/query",
                "esri/symbols/TextSymbol",
                "esri/renderers/SimpleRenderer",
                "esri/layers/LabelLayer",
                "dijit/form/Button",
                "dijit/form/ComboBox",
                "dijit/Dialog",
                "esri/toolbars/draw",
                "dijit/layout/BorderContainer",
                "esri/tasks/GeometryService",
                "dijit/layout/ContentPane",
                "dijit/layout/AccordionContainer",
                "dijit/layout/TabContainer",
                "dijit/layout/SplitContainer",
                "dojox/layout/ExpandoPane",
                "dojox/grid/DataGrid",
                "dojo/data/ItemFileReadStore",
                "agsjs/dijit/TOC",
                "dojo/domReady!"
            function(
                parser,
                Extent,
                 Circle,
                 Memory,
                 ItemFileWriteStore,
                 Grid,
                 EnhancedGrid,
                 CSVWriter,
                 Printer,
                 Selection,
                graphicsUtils,
                SpatialReference,
                on,
                dom,
                registry,
                FindTask,
                FindParameters,
                Map,
                ArcGISDynamicMapServiceLayer,
                InfoTemplate,
                domConstruct,
                Popup,
                IdentifyTask,
                IdentifyResult,
                IdentifyParameters,
                InfoWindow,
                HomeButton,
                FeatureLayer,
                Navigation,
                Legend,
                Print,
                BasemapToggle,
                arrayUtils,
                CheckBox,
                NumberTextBox,
                BasemapGallery,
                Geocoder,
                Color,
                Graphic,
                Geoprocessor,
                SimpleMarkerSymbol,
                screenUtils,
                Measurement,
                OverviewMap,
                Bookmarks,
                BasemapLayer,
                Basemap,
                BookmarkItem,
                Units,
                Geometry,
                Point,
                Polyline,
                Polygon,
                Scalebar,
                AttributeInspector,
                SimpleLineSymbol,
                query,
                SimpleFillSymbol,
                ArcGISTiledMapServiceLayer,
                ImageParameters,
                esriConfig,
                Query,
                TextSymbol,
                SimpleRenderer,
                LabelLayer,
                Button,
                ComboBox,
                Dialog,
                Draw,
                BorderContainer,
                GeometryService,
                ContentPane,
                AccordionContainer,
                TabContainer,
                SplitContainer,
                ExpandoPane,
                DataGrid,
                ItemFileReadStore,
                TOC
KenBuja
Since you're passing the parameter "arrayUtils" in the function, you have to use
RyanSellman
I made the change, but now get an error message saying "Cannot read property '0' if undefined".
KenBuja
Which line are you getting this error?
RyanSellman
In chrome dev tools its saying at line 10 of DataGrid.js...not sure if that helps much.
KenBuja
Are you sure this line is correct?
You've declared that variable with only one item
RyanSellman
  return {
