Select features on multiple feature layers within Polygon
3686
08-20-2013 11:13 AM
tonylife
I am trying to get all features on multiple feature layers inside of a polygon.
I was doing polygon.contains(), it works great for point type feature layer, but not for polyline type or polygon type feature layer.
Then I was directed to implement this in different way, which is doing query on feature layer, by setting query.geomotry = polygon.geometry.
It works fine for single layer, but when it comes to multiple layers, I have trouble to get correct result.
What I am getting, is always the selected features for last layer. Does it clear the selectFeatures result from previous layer every time run for next layer? I did try SELECTION_ADD mode, which is not working either.
Here is the code
var query = new esri.tasks.Query(); query.geometry = area.geometry; var counter = 0; var listOfSelectedFeatures; for (var j = 0; j < map.graphicsLayerIds.length; j++) {  var currentLayer = map.getLayer(map.graphicsLayerIds);      currentLayer.selectFeatures(query, currentLayer.SELECTION_NEW, function () {   counter++;   if (counter == (map.graphicsLayerIds.length - 1)) {    for (var k = 0; k < map.graphicsLayerIds.length; k++) {     var layer = map.getLayer(map.graphicsLayerIds);     if (listOfSelectedFeatures == undefined) {      listOfSelectedFeatures = layer.getSelectedFeatures();     } else {      listOfSelectedFeatures.concat(layer.getSelectedFeatures());     }    }   }  }); }
Tony
JasonZou
Try:
var query = new esri.tasks.Query(); query.geometry = area.geometry; var listOfSelectedFeatures = [];  for (var j = 0; j < map.graphicsLayerIds.length; j++) {  var currentLayer = map.getLayer(map.graphicsLayerIds);             if (currentLayer.declaredClass === "esri.layers.FeatureLayer") {          currentLayer.selectFeatures(query, currentLayer.SELECTION_NEW, function (featureSet) {    listOfSelectedFeatures.concat(featureSet.features);         });         } }
Please be noted that
1. The above code only deals with feature layers. Pure graphics layers should be filtered out since graphics layer has no selectFeatures method.
2. listOfSelectedFeatures may contain features in mixed spatial types.
JasonZou
Try:
ZachLiu1
If you know all the layers you need to select, you may try assign a queryTask for each layer , and after you get the polygon to select features, try"
var queryTask1 = new QueryTask(serviceurl1);
var queryTask2 = new QueryTask(serviceurl2);
var queryTask3 = new QueryTask(serviceurl3);
queryTaskList = [queryTask1, queryTask2,queryTask3...];
var query = new Query();
query.spatialRelationship = Query.SPATIAL_REL_CONTAINS;
var queryTaskToDoList = dojo.map(queryTaskList, function(item, index){
    return item.execute(query)
all(queryTaskToDoList).then(function(featureSetList) { //this function returns a list of feature sets from all queryTask executions.
    dojo.forEach(featureSetList, function(featureSet) {
        listOfSelectedFeatures.push(featureSet);
tonylife
Try:
Thanks for your reminder.
The two points you mentioned does make sense to me.
The key to fix my problem is, the returned parameter "featureSet" for callback function of selectFeatures method.
Things got much easier after knowing there is a featureSet returned by selectFeatures.
Here is the updated code, which is working.
            $.each(areas, function (ind, area) {
                for (var j = 0; j < GISViewer.map.graphicsLayerIds.length; j++) {
                    var currentLayer = GISViewer.map.getLayer(GISViewer.map.graphicsLayerIds);
                    if (currentLayer.visible) {
                                listOfSelectedFeatures.push.apply(listOfSelectedFeatures, featureSet);
tonylife
Thanks for your solution.
Your solution is doing query against service directly which would introduce client server communication.
What I am trying to do is querying feature layer using existed client side data.
I will try your solution when there comes a need.
Thanks again.
Tony
GaneshSolai_Sambandam
Thanks again.
Tony
Hi Tony,
Would able to share your full code incluidng (html, javascript) or put it in a fiddler and it may really help me.
Also, I would like to ask will this work for ARCDynamic Map layers as well.
Regards
Ganesh
