Select and Get Geometry
3231
7
06-27-2014 05:33 AM
jaykapalczynski
Honored Contributor
I want to target a specific Layer in my app (make that selectable to this tool)
Allow the user to select a feature in the map
Get its Geometry and select features inside that geometry
What would be my option?  any examples?
JakeSkinner
Esri Esteemed Contributor
Hi Jay,
Is something like this example what you are looking for?  The app allows you to select a county, and all of the cities within that county are selected.
jaykapalczynski
Honored Contributor
I think I can do something like this
 map.on("click", function(evt) {
            selectQuery.geometry = evt.mapPoint;
            petroFieldsFL.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function(features) {
              if (features.length > 0) {
               //store the current feature
                updateFeature = features[0];
// Dont know how to Highlight the feature
// How do I grab its Geometry and use it for a Buffer Select
              } else {
JakeSkinner
Hi Jay,
jaykapalczynski
Honored Contributor
Yes this is....perfect.....Cheers...I simply need the Geometry of the selected Feature.  I am then using that Geometry to feed an Extract GP tool...
Thanks
jaykapalczynski
Honored Contributor
I do have one last question.
I am doing to below to select a specific feature and create a graphic.  Works fine.
But I cannot turn it off....how do I turn off the MAP CLICK to this feature.  I want to use to have to select the button every time the wish to use this.
        registry.byId("RegionSelection").on("click", function() {
             var highlightSymbol = new SimpleFillSymbol(
       SimpleFillSymbol.STYLE_SOLID,
       new SimpleLineSymbol(
       SimpleLineSymbol.STYLE_SOLID,
       new Color([255, 0, 0]), 1),
       new Color([125, 125, 125, 0.35]));
       petroFieldsFL2.on("click", function (evt) {
          map.graphics.clear();
          highlightGraphic = new Graphic(evt.graphic.geometry, highlightSymbol);
          map.graphics.add(highlightGraphic);
          var query = new Query();
          query.geometry = highlightGraphic.geometry.getExtent();
KenBuja
MVP Esteemed Contributor
Jay, I would suggest reading up on events. The JavaScript API has a good help topic on it and the Dojo documentation for "on" goes into much more detail about how you get more control over events...turning them on and off, pausing them, etc.
jaykapalczynski
Honored Contributor
Thanks Ken...will do. Cheers
jaykapalczynski
Honored Contributor
