second "on layer click event" not fired
3195
01-07-2019 07:38 AM
Pa_Lotus
i have two on layer click events.
scenario is two show two infotemplates when on layer1 is clicked
when on "A" layer is clicked "B" layer is not fired initially
when i click on "B" layer it is working(area code details information)
now code related to "B"  is registered after clicking on it, initially on page load evt it was not registered i guess
Again if i click on "A" layer now both events works(initially it doesn't)
Any suggestions
Thanks
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Non graphic info window</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.27/esri/css/esri.css">
    <style>
      html, body, #map{
        height: 100%;
        margin: 0;
        padding: 0;
    </style>
    <script src="https://js.arcgis.com/3.27/"></script>
    <script>
      var map;
      require([
          "esri/map","esri/dijit/PopupTemplate", "esri/layers/FeatureLayer","esri/InfoTemplate","esri/dijit/Popup",
          "dojo/domReady!"
        ], function(
          Map,PopupTemplate,FeatureLayer,InfoTemplate,PopupMobile
          var service1 = "http://bbb.aaaaa.com/arcgis03/rest/services/aaaa/bbbb/FeatureServer/0";
          var service2 = "http://bbb.aaaaa.com/arcgis03/rest/services/sbc/Territorry/MapServer/2";
          var popup = new PopupMobile(null, dojo.create("div"));
              var Ginfotemplate = InfoTemplate;
          map = new Map("map", {
            basemap: "topo",
            infoWindow: popup,
            center: [-87.6298, 41.8781],
            zoom: 13
 var popupTemplate = new PopupTemplate({
        content: content1
    var popupTemplate2 = new PopupTemplate({
      content: content2
           var layer1 = new FeatureLayer(service1, {
        mode: FeatureLayer.MODE_AUTO,
        infoTemplate: popupTemplate,
        outFields: ["*"],
        "opacity": 0.9
    var Glayer1 = layer1;
     var layer2 = new FeatureLayer(service2, {
       mode: FeatureLayer.MODE_SNAPSHOT,
        infoTemplate: popupTemplate2,
        outFields: ["*"],
        "opacity": 0.5
    var Glayer2 = layer2;
map.addLayers([layer2,layer1]);
 layer1.on("click", function (evt) {
        var idProperty = layer1.objectIdField,
                         feature,
                        featureId,
                        query;
        if (evt.graphic && evt.graphic.attributes && evt.graphic.attributes[idProperty]) {
            feature = evt.graphic,
            featureId = feature.attributes[idProperty];
            Glayer1.infoTemplate = new Ginfotemplate("Title1" , content1);
            popup.show(evt.mapPoint);
      layer2.on("click", function (evt) {
            var idProperty2 = layer2.objectIdField,
                             feature,
                            featureId,
                            query;
            if (evt.graphic && evt.graphic.attributes && evt.graphic.attributes[idProperty2]) {
                featureId = feature.attributes[idProperty2];
                Glayer2.infoTemplate = new Ginfotemplate("Title2", content2);
    </script>
  </head>
  <body>
    <script>
      var content1 = "<table  class='table'><tr><td>Field1</td><td>${Field1}</td></tr>" +
                              "</table>";
     var content2 = "<table  class='table'><tr><td>Teritory</td><td><strong>${Field2}</strong></td></tr>" +
                              "</table>";
    </script>
    <div id="map"></div>
  </body>
</html>
RobertScheitlin__GISP
MR Reddy,
   So you are creating a new Popup dijit so that you can use popup.show? If so then you are wasting effort as you can just use:
map.infoWindow.show(evt.mapPoint);
You are also wasting effort assigning:
Just use the existing layer2 var.
Next you have:
      layer1.on("click", function(evt) {
          feature,
          featureId,
          query;
          Glayer1.infoTemplate = new Ginfotemplate("Title1", content1);
Line 10 you set the layers infoTemplate to a new Ginfotemplate. Which is just a InfoTemplate Class with its content equal to content1. But what is confusing to me is you already set layer1 to have a PopupTemplate class with its content equal to content1.... So this seems very redundant and wasted effort.
when user clicks on 1181 it should load content1 and content2 templates
when user clicks on place where there is no point, only content2 loads in infowindow
When the user click on 1181 only content1 will ever show since a map can only have One popup showing.
If you what a popup to have info from two layers then you have to look into using Arcade expressions.
https://community.esri.com/community/gis/web-gis/arcgisonline/blog/2018/12/10/overlapping-features-i...
MR Reddy,
  Very little of your code make sense to me...  You seem to have two layer that are initialized with a PopupTemplate and then when you click on the layer you want to set the layers infotemplate to a InfoTemplate class that points to the same content?... Why are you creating a Popup dijit when you don't seem to be doing anything with it really? The map class already has a Popup dijit assigned to the map.infoWindow property.
Pa_Lotus
Robert,
made some code changes and two layer click events have different contents,
used popup.show in layer click event
Example layer image, when user clicks on 1181 it should load content1 and content2 templates
MR Reddy,
Next you have:
          feature,
          featureId,
          query;
