SearchWidget ZoomScale
2015
01-29-2019 12:29 PM
JeffreyLafleur1
Hi!
I built my first apps using ver. 4.6 / 4.7 / 4.8 of the JS API.
I was using ZoomScale in the Search Widget to automatically zoom to the search result at a pre-defined zoom.
If I switch my code to ver. 4.9 or 4.10, the ZoomScale isn't working.
Is there a new way to accomplish the same result.
I only want to zoom to a defined scale folowing a search on a selected result.
Thanks!
Jeff
xlt208
by Esri Contributor
Hi Jeffrey,
I was able to reproduce the issue so I went ahead and logged a defect.
  • BUG-000129390: The ZoomScale property fails to set zoom scale for the selected search result from LayerSearchSource.
Just in case you were still experiencing this issue, a workaround would be to set view.scale in a select-result event. For example:
searchWidget.on("select-result"function () {
                        view.goTo({
                            scale: 500000
Apologies for the inconvenience!
Lingtao
Esri Support Services
xlt208
by Esri Contributor
Hi Jeffrey,
                        view.goTo({
                            scale: 500000
Lingtao
JeffreyLafleur1
Thanks, thats exactly the work around that I was using.
Jeffrey
>>> Lingtao Xie <[email protected]> 13/03/20 16:35 >>>
GeoNet, The Esri Community | GIS and Geospatial
Professional Community Re: SearchWidget ZoomScale reply from
Lingtao Xie in ArcGIS API for JavaScript - View the full discussion
Hi Jeffrey,
A workaround would be to set view.scale in a select-result event. For
example:
searchWidget.on("select-result", function () {
view.goTo({
scale: 500000
Lingtao
Reply to this message by replying to this email, or go to the
message on GeoNet, The Esri Community | GIS and Geospatial Professional
Community Start a new discussion in ArcGIS API for
JavaScript by email or at GeoNet, The Esri Community | GIS and
Geospatial Professional Community Following Re: SearchWidget
ZoomScale in these streams: Inbox
This email was sent by GeoNet, The Esri
Community | GIS and Geospatial Professional Community because you are a
registered user.
You may unsubscribe instantly from GeoNet, The
Esri Community | GIS and Geospatial Professional Community, or adjust
email frequency in your email preferences
Avant d'imprimer, pensez à l'environnement.
