Search with in Coded value domain using FindTask
1503
08-23-2019 10:06 AM
NaveedAhmed2
Is it possible to use FindTask to search within descriptions of coded value domain? In the code snippet below I am referring a field of integer type that uses CVD. When I input the value for example 2 or 5 it returns the results but when I try to input string like 'Bike Valet' it does not return anything.
// Create a FindTask pointing to a map service
var find = new FindTask({
url:
"https://services.maps.arizona.edu/pdc/rest/services/DayGato/MapServer/"
// Set parameters to only query the Counties layer by name
var params = new FindParameters({
layerIds: [53],
searchFields: ["RackType"]
Codepen can be found here
by Anonymous User
Not applicable
Hi Naveed,
Provided sample code in an attachment to retrieve the domain information using QueryDomains call. There might be other workarounds. I haven't spend much time, so please feel free to change the code according to your requirements.
NaveedAhmed2
If this is not possible directly then could you please suggest some workaround for this.
by Anonymous User
Not applicable
Hi Naveed,
NaveedAhmed2
Thanks Ravi
by Anonymous User
Not applicable
Glad it worked!!
