Search widget won't zoom??
4346
13
11-30-2018 08:36 AM
KarenEllett
When I create a search widget (using 4.9) when I search for a location using the esri geocoder, it zooms to the result just fine.  But I've also defined a feature layer source, and it WON'T zoom to that result; only pan.  I've tried setting the zoomScale to several different values, but it makes no difference. It will pan, but not zoom.  Any help?? I can't find any examples with zoom at all.
Here's a pared down version:
searchWidgetTest = new Search({
  view: view,
  sources:[{
    featureLayer: new FeatureLayer({
      url: "https://server/arcgis/rest/services/folder/layers/MapServer/0"
  searchFields: ["NAME", "NUMBER"],
  zoomScale:200
Shane_
Thanks Robert. Is there any event I can listen for/use to zoom to the selected feature? The popup is being displayed for the selected feature?
RobertScheitlin__GISP
Shane,
  Sure use select result event:
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Search.html#event-select-...
Use a setTimeout to make sure that the search widget is done with everything it does (some like 500 milliseconds should be good) then do you view.goTo.
Shane_
Thanks Robert, perfect...
// ZOOM TO FEATURE AFTER IT IS SELECTED
searchWidget.on("select-result", function (event) { view.goTo( { zoom: 12 } ); } );
xlt208
by Esri Contributor
Hi all,
I was able to reproduce the issue so I went ahead and logged a defect.
  • BUG-000129390: The ZoomScale property fails to set zoom scale for the selected search result from LayerSearchSource.
Apologies for the inconvenience!
Lingtao
Esri Support Services
