Search Widget on my own data
3317
10-16-2015 03:05 PM
SteveAdams
I have started to make the journey from Flex to javascript.
I am really new at this so forgive me.
I can get my map layer to show up but
  just can't seem to get the search to look at my mapserver
ArcGIS API for JavaScript | Basic Search
<!DOCTYPE html>
<html dir="ltr">
<head>
   <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
   <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
   <title>ArcGIS API for JavaScript | Basic Search</title>
   <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
   <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
   <style>
      html,
      body,
      #map {
         height: 100%;
         width: 100%;
         margin: 0;
         padding: 0;
      #search {
         display: block;
         position: absolute;
         z-index: 2;
         top: 20px;
         left: 74px;
   </style>
   <script src="http://js.arcgis.com/3.14/"></script>
   <script>
       var map;
       require([
        "esri/map",
        "esri/dijit/Search",
        "dojo/domReady!"
      ], function (Map, Search) {
          var initExtent = new esri.geometry.Extent({ "xmin": -119.609356, "ymin": 36.780374, "xmax": -119.797153, "ymax": 36.895779, "spatialReference": { "wkid": 4326} });
          map = new esri.Map("map", { extent: initExtent });
          var MyMapLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://cusdmaps2012.cusd.com/arcgis/rest/services/flex/CUSD_MapFlex3/MapServer", {
          map.addLayer(MyMapLayer);
          var s = new Search({
              enableButtonMode: true, //this enables the search widget to display as a single button
              enableLabel: false,
              enableInfoWindow: true,
              showInfoWindowOnSelect: false,
              map: MyMapLayer
          }, "search");
          var sources = [];
          sources.push({
              featureLayer: new FeatureLayer("http://cusdmaps2012.cusd.com/arcgis/rest/services/flex/CUSD_MapFlex3/MapServer/0"),
              searchFields: ["FULL_ADDRESS"],
              displayField: "FULL_ADDRESS",
              exactMatch: false,
              outFields: ["*"],
              placeholder: "test",
              maxResults: 6,
              maxSuggestions: 6,
              enableSuggestions: true,
              minCharacters: 0
          //Set the sources above to the search widget
          s.set("sources", sources);
          s.startup();
   </script>
</head>
<body>
   <div id="search"></div>
   <div id="map"></div>
</body>
</html>
KellyHutchins
Esri Notable Contributor
Your sample code was missing a few things. First you needed to load esri/layers/FeatureLayer and second in your code that creates the Search widget you were setting the map equal to your dynamic layer. Instead it needed to be the map. Here's a revised version of your code.
<!DOCTYPE html>
<html dir="ltr">
<head>
   <style>
      html,
      body,
      #map {
         height: 100%;
         width: 100%;
         margin: 0;
         padding: 0;
      #search {
         display: block;
         position: absolute;
         z-index: 2;
         top: 20px;
         left: 74px;
   </style>
   <script>
       require([
        "esri/map",
        "esri/geometry/Extent",
        "esri/layers/FeatureLayer",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "dojo/domReady!"
      ], function (Map, Search, Extent, FeatureLayer, ArcGISDynamicMapServiceLayer) {
          var initExtent = new Extent({ "xmin": -119.609356, "ymin": 36.780374, "xmax": -119.797153, "ymax": 36.895779, "spatialReference": { "wkid": 4326} });
          var map = new esri.Map("map", { extent: initExtent });
          var MyMapLayer = ArcGISDynamicMapServiceLayer("http://cusdmaps2012.cusd.com/arcgis/rest/services/flex/CUSD_MapFlex3/MapServer", {
              map: map
          }, "search");
          var sources = [];
          sources.push({
              placeholder: "Enter address",
              outFields: ["*"]
          s.startup();
   </script>
</head>
<body>
</body>
</html>
KellyHutchins
<!DOCTYPE html>
<html dir="ltr">
<head>
   <style>
      html,
      body,
      #map {
         height: 100%;
         width: 100%;
         margin: 0;
         padding: 0;
      #search {
         display: block;
         position: absolute;
         z-index: 2;
         top: 20px;
         left: 74px;
   </style>
   <script>
       require([
        "esri/map",
        "dojo/domReady!"
              map: map
          }, "search");
          var sources = [];
          sources.push({
              outFields: ["*"]
          s.startup();
   </script>
</head>
<body>
</body>
</html>
