Search widget not providing additional Suggestions ie wildcards
6019
8
12-31-2015 10:39 AM
JonahWaterman
I am very new to Javascript and am trying to use the "Search multiple sources" example within the sanbox. I have added a service I would like to search by the plat name however it is not providing me a drop down list like in the example provided.
Below is the example. Has anyone come up with a solution to this or am I just overlooking something. Thanks
<!DOCTYPE html>
<html dir="ltr">
<head>
   <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
   <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
   <title>ArcGIS API for JavaScript | Search widget with multiple sources</title>
   <link rel="stylesheet" href="https://js.arcgis.com/3.15/dijit/themes/claro/claro.css">
   <link rel="stylesheet" href="https://js.arcgis.com/3.15/esri/css/esri.css">
   <style>
      html,
      body,
      #map {
         height: 100%;
         width: 100%;
         margin: 0;
         padding: 0;
      #search {
         display: block;
         position: absolute;
         z-index: 2;
         top: 20px;
         left: 74px;
   </style>
   </script>
<script src="https://js.arcgis.com/3.15/"></script>
   <script>
      require([
        "esri/map", "esri/dijit/Search", "esri/layers/FeatureLayer", "esri/InfoTemplate", "dojo/domReady!"
      ], function (Map, Search, FeatureLayer, InfoTemplate) {
         var map = new Map("map", {
            basemap: "gray",
            center: [-97, 38], // lon, lat
            zoom: 5
         var s = new Search({
            enableButtonMode: true, //this enables the search widget to display as a single button
            enableLabel: false,
            enableInfoWindow: true,
            showInfoWindowOnSelect: false,
            map: map
         }, "search");
         var sources = s.get("sources");
         //Push the sources used to search, by default the ArcGIS Online World geocoder is included. In addition there is a feature layer of US congressional districts. The districts search is set up to find the "DISTRICTID". Also, a feature layer of senator information is set up to find based on the senator name.
         sources.push({
            featureLayer: new FeatureLayer("http://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/CongressionalDistricts/FeatureServe..."),
            searchFields: ["DISTRICTID"],
            displayField: "DISTRICTID",
            exactMatch: false,
            outFields: ["DISTRICTID", "NAME", "PARTY"],
            name: "Congressional Districts",
            placeholder: "3708",
            maxResults: 6,
            maxSuggestions: 6,
            //Create an InfoTemplate and include three fields
            infoTemplate: new InfoTemplate("Congressional District", "District ID: ${DISTRICTID}</br>Name: ${NAME}</br>Party Affiliation: ${PARTY}"),
            enableSuggestions: true,
            minCharacters: 0
         sources.push({
            featureLayer: new FeatureLayer("http://********************/arcgis/rest/services/Apps/SubstationAsBuilts/MapServer/0"),
            searchFields: ["PlatLog.ProName"],
            displayField: "PlatLog.ProName",
            exactMatch: false,
            outFields: ["*"],
            placeholder: "PlatLog.ProName",
            maxResults: 6,
            maxSuggestions: 6,
            infoTemplate: new InfoTemplate("Senator information", "Name: ${PlatLog.ProName}</br>State: ${PlatLog.ProName}</br>Party Affiliation: ${PlatLog.ProName}</br>Phone No: ${PlatLog.ProName}<br><a href=${Web_Page} target=_blank ;'>Website</a>"),
            minCharacters: 0
         //Set the sources above to the search widget
         s.set("sources", sources);
         s.startup();
   </script>
</head>
<body>
   <div id="search"></div>
   <div id="map"></div>
</body>
</html>
RickeyFight
Jonah,
One thing I did notice is that you are not using a feature service.
Secondly I found this
NOTE: Working with suggestions is only available if working with a 10.3 geocoding service that has the suggest capability loaded or a 10.3 feature layer that supports pagination, i.e. supportsPagination = true.
Search widget | Guide | ArcGIS API for JavaScript
Search: "Pagination is not supported."
RickeyFight
Jonah,
Using your code I get this
JonahWaterman
Yah the search actually works however when I type a wildcard like " Forest Hills" it is not returning any suggestions ie. wildcards
such as
Forest Hills  Phase 1
Forest Hills Phase 1 Section 2
Forest Hills Phase 2
JonahWaterman
When searching by Senators or Congressional Districts it will provide 6 suggestions. However when using my service suggestions are not provided image.png
RickeyFight
Jonah,
JonahWaterman
Thanks, so basically I need to have a 10.3 Feature Layer published out and set the supportsPagination = true.
JonahWaterman
Any other recommendations I can preform to get the desired results????
RickeyFight
FadhilahYasin
I encountered the same issue and found this article http://support.esri.com/en/technical-article/000012579. It is easier if you use SDE
