Search comma-separated values
842
12-20-2023 09:09 PM
SaurabhUpadhyaya
Hi Team,
As per the requirement we are trying to implement search based on comma-separated values and display and highlight the results on map. Search will be on layer source or multiple layer source. Important part is performance, it should also be maintain.
We can apply this way but if we have records like 2000 countyname then it is not working .
var whereClause = "COUNTYNAME IN (" + countyArray + ")";
Kindly suggest some workaround to implement this functionality.
Tags (1)
JoelBennett
MVP Regular Contributor
If you're using Oracle, it has a 1000 item limit for the IN operator.  There are various ways around this, and I recommend the answer suggested here.
