SDK and API for 3.4 Unavailable
2907
9
03-28-2013 11:43 AM
DerivenC
Needed to download the SDK & API for 3.4 so I can integrate vsdocs.  Was this overlooked when pushing 3.4?
http://www.esri.com/apps/products/download/index.cfm?fuseaction=download.all#ArcGIS_API_for_JavaScri...
Thanks in advance!
KellyHutchins
Esri Notable Contributor
We are working on it and hope to have the vsdoc ready sometime next week.
Kelly
DerivenC
Thanks for the response and documentation. I'll check back in a couple weeks.Side note: really like the new proxy options. If only I could give it an array, I'd use it instead of my own solution. Nevertheless, it's moving in the right direction.
DerivenC
Or better yet, a function. Anyway that's what I do with each iteration: make a proxy function.
ChadHenningfeld
Kelly
Any update as when the local version of the API will become available?
KellyHutchins
The local version of the api is available for download now:
WayneSzydtowski
there is a problem with the download for "arcgis_js_v34_api.zip"
While the Zip file name is V34, when you unzip the file the enclosed folder name is "arcgiv_js_v33_api"
So, it is really v34 or did someone zip the wrong folder ?
KellyHutchins
Wayne,
Looks like the contents are correct but the folder name is not. We'll get the folder name issue fixed.
Kelly
JanJeske
Now we can get it 🙂
KenBuja
MVP Esteemed Contributor
Do you know when the code assist plugs will be available for 3.4?
