Scipts Hangs when executing query
4774
10
08-30-2013 02:42 AM
vinayb
HI
  I have a  service which is deployed in my local arcgis server which has world country boundries , when i load just a map it works fine but when i add a query task it hangs , the whole browser system and system hangs can anybody tell what could be the reason , i checked in firebug the query response is in milliseconds still it hangs but there are some other request like http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer/tile/2/0/3 and many more of these which take hell lot of time , please let me know what could the issue.Below is query code
var queryTask = new esri.tasks.QueryTask(url);
      var query = new esri.tasks.Query();
      query.returnGeometry = true;
                        query.where = "COUNTRY='India'";
dojo.connect(queryTask, "onComplete", function(featureSet) {
          //alert('calling queryTask'+featureSet);
       //map.graphics.clear();
        try{
         /*var sfs = new SimpleFillSymbol(SimpleFillSymbol.STYLE_FORWARD_DIAGONAL, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.5]));
         alert('somethign');*/
         var symbol = new SimpleFillSymbol(
          SimpleFillSymbol.STYLE_SOLID,
            new Color([255,0,0,0.65]), 2
          new Color([255,0,0,0.35])
         //QueryTask returns a featureSet.  Loop through features in the featureSet and add them to the map.
         dojo.forEach(featureSet.features,function(feature){
          alert('feature'+feature);
          var graphic = feature;
          graphic.setSymbol(symbol);
          alert("infoTemplate"+infoTemplate);
          graphic.setInfoTemplate(infoTemplate);
          alert("graphic"+graphic);
          alert("map.graphics"+map.graphics);
          map.graphics.add(graphic);
       }catch(e){
         alert("e"+e);
     queryTask.execute(query);
initialization of map
var bounds = new Extent({
            "xmin":-16045622,
            "ymin":-811556,
            "xmax":7297718,
            "ymax":11142818,
            "spatialReference":{"wkid":102100}
           map = new esri.Map("map", {
          basemap: "streets",
          zoom: 2
          var url = "http://10.32.9.106:6080/arcgis/rest/services/Demo/World_Countries_v1/MapServer/0";
          var fl = new FeatureLayer(url, {
            //infoTemplate: template
    Below is the rest service
Layer: World_Countires_v1 (ID: 0)
Display Field: COUNTRY
Type: Feature Layer
Geometry Type: esriGeometryPolygon
Description:
Definition Expression:
Copyright Text:
Default Visibility: true
MaxRecordCount: 1000
Supported Query Formats: JSON, AMF
Min Scale: 0
Max Scale: 0
Supports Advanced Queries: false
Supports Statistics: false
Has Labels: false
Can Modify Layer: true
Can Scale Symbols: false
Extent:
    XMin: -179.99999999990004
    YMin: -89.99999999990001
    XMax: 180.00000000010002
    YMax: 83.66549107605236
    Spatial Reference: 4326  (4326)
Drawing Info:
    Renderer:
        Simple Renderer:
        Symbol:
            Style: esriSFSSolid
            Color: [252, 214, 197, 255]
            Outline:
                Style: esriSLSSolid
                Color: [110, 110, 110, 255]
                Width: 0 Label:
        Description: Transparency: 0
    Labeling Info:
HasZ: false
HasM: false
Has Attachments: false
HTML Popup Type: esriServerHTMLPopupTypeAsHTMLText
Type ID Field: null
Fields:
    FID ( type: esriFieldTypeOID , alias: FID )
    Shape ( type: esriFieldTypeGeometry , alias: Shape )
    OBJECTID ( type: esriFieldTypeInteger , alias: OBJECTID )
    COUNTRY ( type: esriFieldTypeString , alias: COUNTRY , length: 50 )
    CONTINENT ( type: esriFieldTypeString , alias: CONTINENT , length: 13 )
    ISO3A ( type: esriFieldTypeString , alias: ISO3A , length: 5 )
    ISO2 ( type: esriFieldTypeString , alias: ISO2 , length: 5 )
Supported Operations:   Query   Generate Renderer   Return Updates
VinayBansal
Have you tried directly querying the rest service in browser?
http://10.32.9.106:6080/arcgis/rest/services/Demo/World_Countries_v1/MapServer/0/query
If not, try it and check if you are getting the result in browser directly.
vinayb
I have and get results quickly form both get and post but sometime get take long time.
vinayb
My Map behaves little picularly on load it looks different after load its diiferent is this issue, I have  attached the images please check  , how can i avaoid this.[ATTACH=CONFIG]27107[/ATTACH][ATTACH=CONFIG]27108[/ATTACH]
VinayBansal
In your code are you getting into the onComplete function? Means where is your process actually hanging?
Also , add error handling event to querytask
dojo.connect(queryTask, "onError", function(error) {
alert(error.description);
vinayb
I am getting in oncompete function i even able to see result of oncompelte too but i think issue is with behavior of map , i have added attachments in my last post for this thread , please look into that and please let me know if that is the issue , if so how can i avoid it.
VinayBansal
This may be due to the different projection system of your map. Do one thing set the coordinate system 102100 in you MXD data frame properties. And re-publish your service
vinayb
Currently we have WGS84 is this a problem
VinayBansal
Regarding your query hangs,have you added your geometry service and your service url in your proxy.config?
vinayb
NO , please let me know if i have to do it and if so how to do it
