Scaling a graphic
3388
7
08-05-2016 09:49 AM
Haider_Ali
I want to scale a  line graphic on scale event and below is the the code of what i am doing
myEditor.editToolbar.on('scale', function(e) {
     var tt = transform(e.graphic.geometry, e.info.scaleX, e.info.scaleY);
     tsymbolGraphic.setGeometry(tt);
          // and then drawing the tsymbolGraphic on map
///and my transform function
function transform(geometry,scaleX,scaleY)
  {  // currently for polyline
  var poly = new Polyline(geometry.spatialReference);
  var screenPoint,mapPoint;
  arrayUtils.forEach(geometry.paths,function(path,i)
  poly.paths = [];
  arrayUtils.forEach(path,function(pnt,j)
  screenPoint = map.toScreen(new Point(pnt[0],pnt[1], geometry.spatialReference));
  screenPoint.x = screenPoint.x * scaleX  + 5  ;
  screenPoint.y = screenPoint.y * scaleY  + 5 ;
  mapPoint =  map.toMap(screenPoint);
  poly.paths = [mapPoint.x,mapPoint.y];
  return poly;
here is the link of full code https://jsfiddle.net/0fy3v8yr/
Tags (1)
thejuskambi
I get what the issue is, The offset happens only when you pan the map. If zoom or change the level, the issue does not occur. Its because, whenever we pan, the 0,0 location of the map/layer is offset and that information is missing while scaling.
To overcome that, add the following to maintain a variable with map delta offsets.
var mapDelta;
map.on("extent-change", function(evt){
     console.log(JSON.stringify(evt.delta));
     if(!evt.levelChange && mapDelta){
          mapDelta.x += evt.delta.x;
          mapDelta.y += evt.delta.y;
      } else {
          mapDelta = evt.delta;
Now the scaling logic will looks like below
screenPoint.x = (refPnt.x + mapDelta.x)  + ((screenPoint.x - (refPnt.x  + mapDelta.x)) * scaleX);
screenPoint.y = (refPnt.y + mapDelta.y) + ((screenPoint.y - (refPnt.y + mapDelta.y)) * scaleY);
thejuskambi
Scale cannot be done similar to move by just using transform. You would have to consider reference point for the scaling.
In the scale event arguments, the info argument contains around property. Roughly, the calculation should be something like below
X = around.x + ((point.x - around.x) * scalex)
Y = around.y + ((point.y - around.y) * scaley)
Sorry I have not verified it.
Haider_Ali
Its working  better this way, try this fiddle
graphicScale - JSFiddle
on some window size  its not working fine (try adjusting the map area in jsfddle  )
thejuskambi
The logic for scaling is working correctly. If I comment the line where you are using geometryEngine.offset. The Red graphic and the editor graphic seems to match.
Haider_Ali
Please  select the line graphic at different zoom level in some its working fine
Haider_Ali
I think its happening if selected graphic is not centered
thejuskambi
var mapDelta;
      } else {
Haider_Ali
Thankyou its working fine,
just added
if( !evt.delta)
       return;
because evt.delta was undefined when i opened developer tool in chrome and resized it
Updated code in the following fiddle
