Saving a Portal Item Back to ArcGIS Online
2112
6
11-12-2013 11:37 AM
BillGrow
Is there a method in the javascript api to save a portal item back to ArcGIS Online after making changes in a custom application? For example adjusting a webmap's initial extent.
~Bill
KellyHutchins
Esri Notable Contributor
This functionality isn't available in the javascript api. In order to update ArcGIS Online content you'll need to use the ArcGIS Portal Rest API:
http://resources.arcgis.com/en/help/arcgis-rest-api/index.html#/Item/02r30000007w000000/
JasonZou
Hi Kelly,
I don't see a REST operation that can be used to update the item data. Can you point out which operation is for editing and updating the item data?
Jason
BillGrow
Thanks Kelly,
I'm just getting back to this issue, so I'll give it a try. Jason, I'm assuming by looking at the page provided, updates can be made using a PUT request http://livedocs.dojotoolkit.org/dojo/request/xhr
~Bill
KellyHutchins
Instead of using dojo/request/xhr take a look at esri.request. It is a utility method that simplifies the process. More info on using esri.request can be found here:
https://developers.arcgis.com/en/javascript/jshelp/inside_esri_request.html
JianHuang
Jason,
Please take a look at the code snippet.
function updateWebMap() {
        var portal = new esri.arcgis.Portal("http://www.arcgis.com/sharing/rest");
        portal.signIn().then(getItem);
function getItem(user) {
        var itemUrl = user.portal.url + "/content/items/" + webMapId;
        var request = esri.request({
          url: itemUrl,
          content: {
            "f": "json"
        request.then(dojo.partial(getWebMapText, user, itemUrl));
function getWebMapText(user, itemUrl, item) {
        if (item.type === "Web Map") {
          //get current webmap text
            url: itemUrl + "/data",
            content: {
              "f": "json"
          request.then(dojo.partial(updateWebMapText, item, user));
        } else {
          alert("Not a Webmap item!");
function updateWebMapText(item, user) {
        var folder = (item.ownerFolder) ? "/" + item.ownerFolder : "";
        var userItemUrl = user.userContentUrl + folder + "/items/" + item.id;
        var webMapText = dojo.toJson(webMapJson);//your updated web map
        var contentUpdate = {
          "text": webMapText,
          "f": "json"
          url: userItemUrl + "/update",
          content: contentUpdate
          usePost: true
        request.then(requestSucceeded);
        //console.log(userItemUrl);
Hi Kelly,
Jason
JasonZou
Cool. Thanks Jian. You always have an answer for my questions:) Happy Thanksgiving!
