Save graphics to feature layer and update attribute value ?
1896
04-21-2019 05:12 AM
MayurDodiya
I am saving graphics in feature service and I would like to add/update Attribute values to feature was just added
Below is the code I am able to Save graphics to Feature layer Service.
function createfreehandline (graphic)
   var freeHLayer = this.map.getLayer('freeHLayer'); // Layer added in map Feature Service layer
freeHLayer.applyEdits([graphic], null, null).then(function (adds, updates, deletes) {
console.log('success', adds);
}, function (err) {
console.log(err);
For Example, with above code new feature with ObjectId added, now I want to update attribute value in Field name "JOBNO"
How can I update the attribute value of feature that was just added ?
MayurDodiya
Hi Ken,
Thanks for your reply.
After adding below line I was getting error " Cannot set property 'JOBNO' of undefined"
graphic.attributes["JOBNO"] = newAttribute;
So, I Created new object then add attributes to object and set to graphic. Below code worked for me
var SaveAttribute = new Object();
SaveAttribute.JOBNO= newAttribute;
graphic.attributes = SaveAttribute;
 }, function (err) {
 console.log(err);
KenBuja
MVP Esteemed Contributor
Before you call applyEdits, change the attribute of the graphic to the value newAttribute
MayurDodiya
Hi Ken,
 }, function (err) {
 console.log(err);
